Camera model Insta 360OneR
What is the problem? The camera was running initially but after a few uses now it doesn't want to show any image in the stream!
Screenshot 2020-12-21 121611|612x350
What did you already try to solve it? I am not sure what to do.
pi@PrusaMK3S:~ $ journalctl -u webcamd
-- Logs begin at Mon 2020-12-21 00:17:21 PST, end at Mon 2020-12-21 12:03:16 PST
Dec 21 11:47:32 PrusaMK3S systemd[1]: Starting the OctoPi webcam daemon with the
Dec 21 11:47:32 PrusaMK3S webcamd[332]: Starting up webcamDaemon...
Dec 21 11:47:32 PrusaMK3S webcamd[332]: --- Configuration: ---------------------
Dec 21 11:47:32 PrusaMK3S webcamd[332]: cfg_file: /boot/octopi.txt
Dec 21 11:47:32 PrusaMK3S webcamd[332]: camera: auto
Dec 21 11:47:32 PrusaMK3S webcamd[332]: usb options: -r 640x480 -f 10
Dec 21 11:47:32 PrusaMK3S webcamd[332]: raspi options: -fps 10
Dec 21 11:47:32 PrusaMK3S webcamd[332]: http options: -w ./www-octopi -n
Dec 21 11:47:32 PrusaMK3S webcamd[332]: Explicitly USB device:
Dec 21 11:47:32 PrusaMK3S webcamd[332]: ----------------------------------------
Dec 21 11:47:32 PrusaMK3S webcamd[332]: Found video devices:
Dec 21 11:47:32 PrusaMK3S webcamd[332]: /dev/video10
Dec 21 11:47:32 PrusaMK3S webcamd[332]: /dev/video11
Dec 21 11:47:32 PrusaMK3S webcamd[332]: /dev/video12
Dec 21 11:47:32 PrusaMK3S webcamd[332]: config file='/boot/octopi.txt':USB devic
Dec 21 11:47:33 PrusaMK3S webcamd[332]: /root/bin/webcamd: line 153: printf: 0x:
Dec 21 11:47:33 PrusaMK3S root[442]: Starting USB webcam
Dec 21 11:47:33 PrusaMK3S webcamd[332]: <13>Dec 21 11:47:33 root: Starting USB w
Dec 21 11:47:33 PrusaMK3S webcamd[332]: Running ./mjpg_streamer -o output_http.s
Dec 21 11:47:33 PrusaMK3S mjpg_streamer[450]: MJPG-streamer [450]: starting appl
Dec 21 11:47:33 PrusaMK3S mjpg_streamer[450]: MJPG-streamer [450]: MJPG Streamer
Dec 21 11:47:33 PrusaMK3S webcamd[332]: MJPG Streamer Version: git rev: 501f6362
lines 1-23...skipping...
-- Logs begin at Mon 2020-12-21 00:17:21 PST, end at Mon 2020-12-21 12:03:16 PST. --
Dec 21 11:47:32 PrusaMK3S systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Dec 21 11:47:32 PrusaMK3S webcamd[332]: --- Configuration: ----------------------------
Dec 21 11:47:32 PrusaMK3S webcamd[332]: -----------------------------------------------
Dec 21 11:47:32 PrusaMK3S webcamd[332]: config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found v
Dec 21 11:47:33 PrusaMK3S webcamd[332]: /root/bin/webcamd: line 153: printf: 0x: invalid hex number
Dec 21 11:47:33 PrusaMK3S webcamd[332]: <13>Dec 21 11:47:33 root: Starting USB webcam
Dec 21 11:47:33 PrusaMK3S webcamd[332]: Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i input_uvc.so -r 640x480 -f 10 -d /dev/video1
Dec 21 11:47:33 PrusaMK3S mjpg_streamer[450]: MJPG-streamer [450]: starting application
Dec 21 11:47:33 PrusaMK3S mjpg_streamer[450]: MJPG-streamer [450]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
Dec 21 11:47:33 PrusaMK3S webcamd[332]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
Dec 21 11:47:33 PrusaMK3S webcamd[332]: i: Using V4L2 device.: /dev/video10
Dec 21 11:47:33 PrusaMK3S webcamd[332]: i: Desired Resolution: 640 x 480
Dec 21 11:47:33 PrusaMK3S webcamd[332]: i: Frames Per Second.: 10
Dec 21 11:47:33 PrusaMK3S webcamd[332]: i: Format............: JPEG
Dec 21 11:47:33 PrusaMK3S webcamd[332]: i: TV-Norm...........: DEFAULT
Dec 21 11:47:33 PrusaMK3S mjpg_streamer[450]: MJPG-streamer [450]: Using V4L2 device.: /dev/video10
Dec 21 11:47:33 PrusaMK3S mjpg_streamer[450]: MJPG-streamer [450]: Desired Resolution: 640 x 480
Dec 21 11:47:33 PrusaMK3S mjpg_streamer[450]: MJPG-streamer [450]: Frames Per Second.: 10
Dec 21 11:47:33 PrusaMK3S mjpg_streamer[450]: MJPG-streamer [450]: Format............: JPEG
Dec 21 11:47:33 PrusaMK3S mjpg_streamer[450]: MJPG-streamer [450]: TV-Norm...........: DEFAULT
Dec 21 11:47:33 PrusaMK3S webcamd[332]: Error opening device /dev/video10: video capture not supported.
Dec 21 11:47:33 PrusaMK3S webcamd[332]: Init v4L2 failed !! exit fatal
Dec 21 11:47:33 PrusaMK3S webcamd[332]: i: init_VideoIn failed
Dec 21 11:47:33 PrusaMK3S mjpg_streamer[450]: MJPG-streamer [450]: init_VideoIn failed
lines 1-37...skipping...
Dec 21 11:47:34 PrusaMK3S webcamd[332]: Done bring up all configured video device
Dec 21 11:47:34 PrusaMK3S webcamd[332]: Goodbye...
Dec 21 11:47:34 PrusaMK3S systemd[1]: webcamd.service: Succeeded.
Dec 21 11:47:34 PrusaMK3S systemd[1]: Started the OctoPi webcam daemon with the user specified config.
Dec 21 11:47:34 PrusaMK3S systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling restart.
Dec 21 11:47:34 PrusaMK3S systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 1.
Dec 21 11:47:34 PrusaMK3S systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Dec 21 11:47:34 PrusaMK3S systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Dec 21 11:47:34 PrusaMK3S webcamd[500]: Starting up webcamDaemon...
Dec 21 11:47:34 PrusaMK3S webcamd[500]: --- Configuration: ----------------------------
Dec 21 11:47:34 PrusaMK3S webcamd[500]: cfg_file: /boot/octopi.txt
Dec 21 11:47:34 PrusaMK3S webcamd[500]: camera: auto
Dec 21 11:47:34 PrusaMK3S webcamd[500]: usb options: -r 640x480 -f 10
OctoPrint version --> Version 1.5.2
OctoPi version --> Version 0.17.0, running on Raspberry Pi 4 Model B Rev 1.1
Any help will be appreciated
