Version 0.18.0, running on Raspberry Pi 4 Model B Rev 1.1
USB Cheap Chinese Model from Amazon
Bus 001 Device 003: ID 05a3:9331 ARC International Camera
Turn on Pi 4, haven't turned on 3D printer yet, and the camera works fine. Can see the camera image in both OctoPi web interface - Control tab, and also in browser using URL 3dprinter.local/webcam/?action=stream.
Now if I either leave the Pi running with the 3D printer off or if I use the 3D printer and then turn off the 3D printer, the camera eventually dies and never comes back on line again. I cant even directly stream the camera using just the web URL (so I know its not Octoprint).
I tried to SSH on the Pi and run
sudo service webcamd restart
But it still wont start up. The only thing I can do is reboot the Pi. Anybody seen anything similar ?
/var/log/syslog
Jul 1 18:15:08 3DPrinter root: Starting USB webcam
Jul 1 18:15:08 3DPrinter MJPG-streamer [32475]: starting application
Jul 1 18:15:08 3DPrinter MJPG-streamer [32475]: MJPG Streamer Version: git rev: 5554f42c352ecfa7edaec6fc51e507afce605a34
Jul 1 18:15:08 3DPrinter MJPG-streamer [32475]: Using V4L2 device.: /dev/video10
Jul 1 18:15:08 3DPrinter MJPG-streamer [32475]: Desired Resolution: 640 x 480
Jul 1 18:15:08 3DPrinter MJPG-streamer [32475]: Frames Per Second.: 10
Jul 1 18:15:08 3DPrinter MJPG-streamer [32475]: Format............: JPEG
Jul 1 18:15:08 3DPrinter MJPG-streamer [32475]: TV-Norm...........: DEFAULT
Jul 1 18:15:08 3DPrinter MJPG-streamer [32475]: init_VideoIn failed
Jul 1 18:15:09 3DPrinter systemd[1]: webcamd.service: Succeeded.
Jul 1 18:15:09 3DPrinter systemd[1]: Started the OctoPi webcam daemon with the user specified config.
Jul 1 18:15:10 3DPrinter systemd[1]: webcamd.service: Service RestartSec=1s expired, scheduling restart.
Jul 1 18:15:10 3DPrinter systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 1020.
Jul 1 18:15:10 3DPrinter systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Jul 1 18:15:10 3DPrinter systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Jul 1 18:15:10 3DPrinter root: Starting USB webcam
Jul 1 18:15:10 3DPrinter MJPG-streamer [32501]: starting application
Jul 1 18:15:10 3DPrinter MJPG-streamer [32501]: MJPG Streamer Version: git rev: 5554f42c352ecfa7edaec6fc51e507afce605a34
Jul 1 18:15:10 3DPrinter MJPG-streamer [32501]: Using V4L2 device.: /dev/video10
Jul 1 18:15:10 3DPrinter MJPG-streamer [32501]: Desired Resolution: 640 x 480
Jul 1 18:15:10 3DPrinter MJPG-streamer [32501]: Frames Per Second.: 10
Jul 1 18:15:10 3DPrinter MJPG-streamer [32501]: Format............: JPEG
Jul 1 18:15:10 3DPrinter MJPG-streamer [32501]: TV-Norm...........: DEFAULT
Jul 1 18:15:10 3DPrinter MJPG-streamer [32501]: init_VideoIn failed
dmesg
[ 4.699537] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 4.700056] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 4.700483] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 4.700991] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 4.701020] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 4.701042] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 4.701062] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 4.701081] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 4.701297] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 4.751101] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.032174] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 5.041512] uvcvideo: Found UVC 1.00 device HD Web Camera (05a3:9331)
[ 5.042143] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.087462] uvcvideo: Failed to query (GET_INFO) UVC control 9 on unit 2: -32 (exp. 1).
[ 5.114004] uvcvideo: Failed to query (GET_INFO) UVC control 4 on unit 2: -32 (exp. 1).
[ 5.140022] uvcvideo: Failed to query (GET_INFO) UVC control 11 on unit 2: -32 (exp. 1).
[ 5.143738] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 5.143761] checking generic (3e843000 384000) vs hw (0 ffffffffffffffff)
[ 5.143777] fb0: switching to vc4drmfb from simple
[ 5.144479] Console: switching to colour dummy device 80x30
[ 5.144765] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.144778] [drm] No driver support for vblank timestamp query.
[ 5.144791] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 5.145394] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 5.149780] vc4-drm gpu: HDMI-A-1: EDID is invalid:
[ 5.149800] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5.149814] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5.149827] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5.149840] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5.149853] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5.149866] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5.149879] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5.149892] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5.185470] input: HD Web Camera: HD Web Camera as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input0
[ 5.187870] usbcore: registered new interface driver uvcvideo
[ 5.187882] USB Video Class driver (1.1.1)
[ 5.198082] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.295522] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.297404] Console: switching to colour frame buffer device 160x45
[ 5.311592] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.312031] usbcore: registered new interface driver brcmfmac
[ 5.319154] vc4-drm gpu: fb0: vc4drmfb frame buffer device
[ 5.339620] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[ 5.383567] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.383613] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.390805] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.390854] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.397313] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.397357] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.401780] usb 1-1.4: Warning! Unlikely big volume range (=3072), cval->res is probably wrong.
[ 5.401803] usb 1-1.4: [6] FU [Mic Capture Volume] ch = 1, val = -1536/1536/1
[ 5.402658] usbcore: registered new interface driver snd-usb-audio
[ 5.576698] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.588391] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Apr 15 2021 03:02:07 version 7.45.234 (4ca95bb CY) FWID 01-4f919496
[ 7.253438] uart-pl011 fe201000.serial: no DMA platform data
[ 7.435824] 8021q: 802.1Q VLAN Support v1.8
[ 7.518144] random: crng init done
[ 7.518161] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.794016] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.005790] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 8.437073] bcmgenet: Skipping UMAC reset
[ 8.439863] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 8.440265] bcmgenet fd580000.ethernet eth0: Link is Down
[ 8.521999] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
[ 13.964005] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 14.052742] Bluetooth: Core ver 2.22
[ 14.052840] NET: Registered protocol family 31
[ 14.052852] Bluetooth: HCI device and connection manager initialized
[ 14.053205] Bluetooth: HCI socket layer initialized
[ 14.053224] Bluetooth: L2CAP socket layer initialized
[ 14.053258] Bluetooth: SCO socket layer initialized
[ 14.065727] Bluetooth: HCI UART driver ver 2.3
[ 14.065745] Bluetooth: HCI UART protocol H4 registered
[ 14.065838] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.066113] Bluetooth: HCI UART protocol Broadcom registered
[ 14.223288] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.223295] Bluetooth: BNEP filters: protocol multicast
[ 14.223308] Bluetooth: BNEP socket layer initialized
[ 23.928333] fuse: init (API version 7.31)
[ 25.874134] Bluetooth: RFCOMM TTY layer initialized
[ 25.874151] Bluetooth: RFCOMM socket layer initialized
[ 25.874169] Bluetooth: RFCOMM ver 1.11
[89936.548790] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[89942.788881] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[89949.028967] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[89955.269058] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[89961.509089] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[89967.829169] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[89974.069341] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[89980.309414] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[89986.550756] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[89992.789598] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[89999.029764] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90005.269812] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90011.509891] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90017.749886] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90023.989995] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90030.310165] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90036.470179] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90042.710414] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90049.030367] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90055.270454] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90061.510553] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90067.750704] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90073.990752] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90080.230873] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90086.550943] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90092.711142] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90099.031179] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90105.271252] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90111.511431] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90117.751453] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90123.991513] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90130.311597] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90136.471678] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90142.711781] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90149.031947] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90155.273215] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90161.512226] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90167.752363] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90174.072455] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90180.232531] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90186.552607] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90192.792779] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90199.032808] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90205.272910] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90211.513124] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90217.753222] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90223.993258] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90230.313382] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90236.553508] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90242.793671] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90249.033717] uvcvideo: Failed to set UVC probe control : -110 (exp. 26).
[90252.013499] uvcvideo: Failed to set UVC probe control : -71 (exp. 26).
[90252.199518] usb 1-1.4: USB disconnect, device number 3
[90252.603567] usb 1-1.4: new high-speed USB device number 4 using xhci_hcd
[90255.063864] usb 1-1.4: device descriptor read/64, error -71
[90270.414120] usb 1-1.4: device descriptor read/64, error -110
[90270.633905] usb 1-1.4: new high-speed USB device number 5 using xhci_hcd
[90275.774230] usb 1-1.4: device descriptor read/64, error -110
[90291.134533] usb 1-1.4: device descriptor read/64, error -110
[90291.254703] usb 1-1-port4: attempt power cycle
[90291.914280] usb 1-1.4: new high-speed USB device number 6 using xhci_hcd
[90293.501811] usb 1-1.4: Device not responding to setup address.
[90295.310723] usb 1-1.4: Device not responding to setup address.
[90295.524363] usb 1-1.4: device not accepting address 6, error -71
[90295.624340] usb 1-1.4: new high-speed USB device number 7 using xhci_hcd
[90297.210826] usb 1-1.4: Device not responding to setup address.
[90299.010732] usb 1-1.4: Device not responding to setup address.
[90299.224392] usb 1-1.4: device not accepting address 7, error -71
[90299.224770] usb 1-1-port4: unable to enumerate USB device
[92756.402408] usb 1-1.1: new full-speed USB device number 8 using xhci_hcd
[92756.537809] usb 1-1.1: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
[92756.537829] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[92756.537846] usb 1-1.1: Product: CP2102 USB to UART Bridge Controller
[92756.537862] usb 1-1.1: Manufacturer: Silicon Labs
[92756.537878] usb 1-1.1: SerialNumber: 0001
[92756.601354] usbcore: registered new interface driver usbserial_generic
[92756.601427] usbserial: USB Serial support registered for generic
[92756.606419] usbcore: registered new interface driver cp210x
[92756.606542] usbserial: USB Serial support registered for cp210x
[92756.606718] cp210x 1-1.1:1.0: cp210x converter detected
[92756.615984] usb 1-1.1: cp210x converter now attached to ttyUSB0
[92756.642362] usb 1-1.4: new high-speed USB device number 9 using xhci_hcd
[92761.812702] usb 1-1.4: device descriptor read/64, error -110
[92777.172891] usb 1-1.4: device descriptor read/64, error -110
[92777.392690] usb 1-1.4: new high-speed USB device number 10 using xhci_hcd
[92782.532978] usb 1-1.4: device descriptor read/64, error -110
[92797.893174] usb 1-1.4: device descriptor read/64, error -110
[92798.013343] usb 1-1-port4: attempt power cycle
[92798.672970] usb 1-1.4: new high-speed USB device number 11 using xhci_hcd
[92800.628029] usb 1-1.4: Device not responding to setup address.
[92802.797909] usb 1-1.4: Device not responding to setup address.
[92803.013039] usb 1-1.4: device not accepting address 11, error -71
[92803.113045] usb 1-1.4: new high-speed USB device number 12 using xhci_hcd
[92805.067953] usb 1-1.4: Device not responding to setup address.
[92807.237967] usb 1-1.4: Device not responding to setup address.
[92807.453122] usb 1-1.4: device not accepting address 12, error -71
[92807.453596] usb 1-1-port4: unable to enumerate USB device
browser.user_agent : Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.5060.53 Safari/537.36
connectivity.connection_check : 1.1.1.1:53
connectivity.connection_ok : true
connectivity.enabled : false
connectivity.online : true
connectivity.resolution_check : octoprint.org
connectivity.resolution_ok : true
env.hardware.cores : 4
env.hardware.freq : 1500
env.hardware.ram : 3959984128
env.os.bits : 32
env.os.id : linux
env.os.platform : linux
env.plugins.pi_support.model : Raspberry Pi 4 Model B Rev 1.1
env.plugins.pi_support.octopi_version : 0.18.0
env.plugins.pi_support.throttle_check_enabled : true
env.plugins.pi_support.throttle_check_functional : true
env.plugins.pi_support.throttle_state : 0x0
env.python.pip : 20.3.3
env.python.version : 3.7.3
env.python.virtualenv : true
octoprint.last_safe_mode.date : unknown
octoprint.last_safe_mode.reason : unknown
octoprint.safe_mode : false
octoprint.version : 1.8.1
systeminfo.generated : 2022-07-02T01:36:43Z
systeminfo.generator : systemapi
