Creative Live Sync HD
The web interface only shows the camera feed for about a minute then stops. It's also not streaming at the configured rate.
webcamd.log:
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: usb
usb options: -r HD -f 1
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video2
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video1
<13>Mar 3 21:52:03 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r HD -f 1 -d /dev/video1
i: Using V4L2 device.: /dev/video1
i: Desired Resolution: 1280 x 720
i: Frames Per Second.: 1
i: Format............: JPEG
i: FPS coerced ......: from 1 to 30
o: HTTP Listen Address..: 127.0.0.1
dmesg
[ 2111.328631] usb 1-1.4: new high-speed USB device number 5 using xhci_hcd
[ 2111.474804] usb 1-1.4: New USB device found, idVendor=041e, idProduct=409f, bcdDevice=31.01
[ 2111.474824] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2111.474841] usb 1-1.4: Product: Live! Cam Sync 1080p
[ 2111.474857] usb 1-1.4: Manufacturer: Creative Technology Ltd.
[ 2111.474872] usb 1-1.4: SerialNumber: Live! Cam Sync 1080p Audio
[ 2111.476955] uvcvideo: Found UVC 1.00 device Live! Cam Sync 1080p (041e:409f)
[ 2111.489814] input: Live! Cam Sync 1080p: Live! Cam as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input1
Raspberry Pi 4
OctoPrint 1.5.3
OctoPi Version 0.18.0
The symptom is that in the box on the UI where the video should be, it goes black with an icon in the center like it doesn't know what the type is. Refreshing the window seems to bring the video back for another minute, then it stops.
I've tried lowering FPS from 30 to 10 to 1, and in the 1 minute or so that the stream works it appears to be streaming at full FPS. But the log clearly shows it's lowering from 30 to 1.
Also interesting, even though the browser stops getting the stream the server software is still sending it, as witnessed by lots of data seen in tcpdump (and if I kill mjpg_streamer , the data rate drops way down).
I've tried the UI on two different computers (one Mac, one Windows), on different browsers (Chrome & Safari on the Mac, Chrome and Edge on Windows).
