I can´t connect my Sovol SV01 using a BTT SKR Mini E3 v1.2 anymore via USB. It worked well for quite a while and now doesn´t. I changed cable and even used other RPi hardware (3B and 4) - no result.
I activated the Serial log, posted below.
I tried to look for similiar issues but didn´t get further.
Thanks for any help or good ideas.
octoprint-systeminfo-20260212213741.zip (7.8 KB)
Logged into octopi via putty and executed the following commands:
lsusb
octopi@octopi:~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 1d50:614e OpenMoko, Inc. stm32f103xe
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
octopi@octopi:~ $ dmesg | grep usb
[ 0.105215] usbcore: registered new interface driver usbfs
[ 0.105268] usbcore: registered new interface driver hub
[ 0.105328] usbcore: registered new device driver usb
[ 1.848951] usbcore: registered new device driver r8152-cfgselector
[ 1.849008] usbcore: registered new interface driver r8152
[ 1.849058] usbcore: registered new interface driver lan78xx
[ 1.849107] usbcore: registered new interface driver smsc95xx
[ 1.855432] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 1.855466] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.855494] usb usb1: Product: xHCI Host Controller
[ 1.855514] usb usb1: Manufacturer: Linux 6.6.51+rpt-rpi-v7l xhci-hcd
[ 1.855535] usb usb1: SerialNumber: 0000:01:00.0
[ 1.856759] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 1.856794] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.856822] usb usb2: Product: xHCI Host Controller
[ 1.856842] usb usb2: Manufacturer: Linux 6.6.51+rpt-rpi-v7l xhci-hcd
[ 1.856862] usb usb2: SerialNumber: 0000:01:00.0
[ 1.859000] usbcore: registered new interface driver uas
[ 1.859077] usbcore: registered new interface driver usb-storage
[ 1.865516] usbcore: registered new interface driver usbhid
[ 1.865538] usbhid: USB HID core driver
[ 2.144445] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 2.321221] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 2.321274] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.321302] usb 1-1: Product: USB2.0 Hub
[ 2.668353] usb 1-1.1: new full-speed USB device number 3 using xhci_hcd
[ 2.827525] usb 1-1.1: New USB device found, idVendor=1d50, idProduct=614e, bcdDevice= 1.00
[ 2.827576] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.827607] usb 1-1.1: Product: stm32f103xe
[ 2.827628] usb 1-1.1: Manufacturer: Klipper
[ 2.827648] usb 1-1.1: SerialNumber: 35FFD805524E343530670543
[ 8.084668] usbcore: registered new interface driver cdc_acm
[ 8.449284] usbcore: registered new interface driver brcmfmac
Serial Log:
2026-02-08 18:57:50,711 - Changing monitoring state from "Offline" to "Opening serial connection"
2026-02-08 18:57:50,719 - Connecting to port /dev/ttyACM0, baudrate 115200
2026-02-08 18:57:50,741 - Changing monitoring state from "Opening serial connection" to "Connecting"
2026-02-08 18:57:50,743 - Connected to: Serial<id=0xacc791d8, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2026-02-08 18:57:50,746 - Send: N0 M110 N0*125
2026-02-08 18:58:31,739 - No answer from the printer within the connection timeout, trying another hello
2026-02-08 18:58:31,740 - Send: N0 M110 N0*125
2026-02-08 18:58:46,738 - There was a timeout while trying to connect to the printer
2026-02-08 18:58:46,748 - Changing monitoring state from "Connecting" to "Offline"
2026-02-08 18:58:46,752 - Connection closed, closing down monitor
2026-02-08 19:05:03,932 - Changing monitoring state from "Offline" to "Detecting serial connection"
2026-02-08 19:05:03,952 - Performing autodetection with 7 port/baudrate candidates: /dev/ttyACM0@115200, /dev/ttyACM0@250000, /dev/ttyACM0@230400, /dev/ttyACM0@57600, /dev/ttyACM0@38400, /dev/ttyACM0@19200, /dev/ttyACM0@9600
2026-02-08 19:05:03,953 - Trying port /dev/ttyACM0, baudrate 115200
2026-02-08 19:05:03,954 - Connecting to port /dev/ttyACM0, baudrate 115200
2026-02-08 19:05:03,975 - Handshake attempt #1 with timeout 2.0s
2026-02-08 19:05:03,980 - Connected to: Serial<id=0xaf28bdc0, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2026-02-08 19:05:03,986 - Send: N0 M110 N0*125
2026-02-08 19:05:05,985 - Handshake attempt #2 with timeout 2.0s
2026-02-08 19:05:05,993 - Send: N0 M110 N0*125
2026-02-08 19:05:08,757 - Handshake attempt #3 with timeout 2.0s
2026-02-08 19:05:08,765 - Send: N0 M110 N0*125
2026-02-08 19:05:10,765 - Trying port /dev/ttyACM0, baudrate 250000
2026-02-08 19:05:10,771 - Handshake attempt #1 with timeout 2.0s
2026-02-08 19:05:10,775 - Send: N0 M110 N0*125
2026-02-08 19:05:13,757 - Handshake attempt #2 with timeout 2.0s
2026-02-08 19:05:13,765 - Send: N0 M110 N0*125
2026-02-08 19:05:15,765 - Handshake attempt #3 with timeout 2.0s
2026-02-08 19:05:15,772 - Send: N0 M110 N0*125
2026-02-08 19:05:18,757 - Trying port /dev/ttyACM0, baudrate 230400
2026-02-08 19:05:18,762 - Handshake attempt #1 with timeout 2.0s
2026-02-08 19:05:18,768 - Send: N0 M110 N0*125
2026-02-08 19:05:20,766 - Handshake attempt #2 with timeout 2.0s
2026-02-08 19:05:20,773 - Send: N0 M110 N0*125
2026-02-08 19:05:23,757 - Handshake attempt #3 with timeout 2.0s
2026-02-08 19:05:23,767 - Send: N0 M110 N0*125
2026-02-08 19:05:25,766 - Trying port /dev/ttyACM0, baudrate 57600
2026-02-08 19:05:25,771 - Handshake attempt #1 with timeout 2.0s
2026-02-08 19:05:25,776 - Send: N0 M110 N0*125
2026-02-08 19:05:28,757 - Handshake attempt #2 with timeout 2.0s
2026-02-08 19:05:28,765 - Send: N0 M110 N0*125
2026-02-08 19:05:30,764 - Handshake attempt #3 with timeout 2.0s
2026-02-08 19:05:30,771 - Send: N0 M110 N0*125
2026-02-08 19:05:33,757 - Trying port /dev/ttyACM0, baudrate 38400
2026-02-08 19:05:33,761 - Handshake attempt #1 with timeout 2.0s
2026-02-08 19:05:33,768 - Send: N0 M110 N0*125
2026-02-08 19:05:35,769 - Handshake attempt #2 with timeout 2.0s
2026-02-08 19:05:35,776 - Send: N0 M110 N0*125
2026-02-08 19:05:38,758 - Handshake attempt #3 with timeout 2.0s
2026-02-08 19:05:38,765 - Send: N0 M110 N0*125
2026-02-08 19:05:40,765 - Trying port /dev/ttyACM0, baudrate 19200
2026-02-08 19:05:40,769 - Handshake attempt #1 with timeout 2.0s
2026-02-08 19:05:40,774 - Send: N0 M110 N0*125
2026-02-08 19:05:43,757 - Handshake attempt #2 with timeout 2.0s
2026-02-08 19:05:43,764 - Send: N0 M110 N0*125
2026-02-08 19:05:45,764 - Handshake attempt #3 with timeout 2.0s
2026-02-08 19:05:45,771 - Send: N0 M110 N0*125
2026-02-08 19:05:48,757 - Trying port /dev/ttyACM0, baudrate 9600
2026-02-08 19:05:48,762 - Handshake attempt #1 with timeout 2.0s
2026-02-08 19:05:48,767 - Send: N0 M110 N0*125
2026-02-08 19:05:50,768 - Handshake attempt #2 with timeout 2.0s
2026-02-08 19:05:50,775 - Send: N0 M110 N0*125
2026-02-08 19:05:53,757 - Handshake attempt #3 with timeout 2.0s
2026-02-08 19:05:53,764 - Send: N0 M110 N0*125
2026-02-08 19:05:55,765 - Changing monitoring state from "Detecting serial connection" to "Error"
2026-02-08 19:05:55,785 - Changing monitoring state from "Error" to "Offline after error"
2026-02-08 19:05:55,791 - Connection closed, closing down monitor
