What is the problem
I have a Prusa MK3S+ that had been working well for over a year. I have an RPi3 + OctoPi running for several hundred hours of printing with 0 issues.
After one particular failed print, we had to do an emergency stop, and ever since, Octoprint fails to negotiate serial, or more correctly it fails to get a response from the Prusa controller board, but I can't figure out why.
I'm still able to print via SD card and the control circuit still "initializes" with an LCD screen restart whenever I try to connect serial from Octoprint.
- I've tried multiple power supplies, thinking there was a voltage sag causing serial problems -> no help
- I loaded the OctoPi package on a different (model) raspberryPi -> Same problem persisted
- tried upgrading the firmware to the latest on the printer via laptop -> worked but Didn't help
- tried downgrading firmware back to the last known functional version via laptop -> worked but didn't help.
- Loaded octoprint on the (same) M1 macbook and tried running the serial connection there.
I've tried safe mode.
The serial behavior is the same in safe mode.
octoprint-systeminfo-20230807193934.zip (112.2 KB)
Sysinfo attached.
- RPi 3B
- Prusa MK3S+
- OctoPrint 1.9.2
- Python 3.7.3
- OctoPi* 0.18.0 (build 2022.10.18.093204
dmesg output on Rpi for Prusa serial connection:
[15361.736068] usb 1-1.4: new full-speed USB device number 4 using dwc_otg
[15361.883114] usb 1-1.4: New USB device found, idVendor=2c99, idProduct=0002, bcdDevice= 1.30
[15361.883141] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[15361.883157] usb 1-1.4: Product: Original Prusa i3 MK3
[15361.883172] usb 1-1.4: Manufacturer: Prusa Research (prusa3d.com)
[15361.883187] usb 1-1.4: SerialNumber: CZPX3522X004XK81675
[15361.936305] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
[15361.937334] usbcore: registered new interface driver cdc_acm
[15361.937350] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Terminal output on attemption connect:
Changing monitoring state from "Offline" to "Opening serial connection"
Connecting to port /dev/ttyACM0, baudrate 19200
Changing monitoring state from "Opening serial connection" to "Connecting"
Connected to: Serial<id=0x7075e770, open=True>(port='/dev/ttyACM0', baudrate=19200, bytesize=8, parity='N', stopbits=1, timeout=5.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
Thanks in advance.
Dan
