Usb usb1-port1: disabled by hub (EMI?), re-enabling
HBVCAM 5M-AF
So this is funny, because the setup has mostly worked before, but refuses to now. Whenever I print for a while and have my USB camera module connected to the Pi, either the webcam fails on it's own (hanging the webcamd service) or the serial communications get taken with it. I have boiled the issue down to the following dmesg entry:
usb usb1-port1: disabled by hub (EMI?), re-enabling...
Apparently, the Pi restarts USB randomly. This does not happen when the camera module is not connected, and also doesn't happen when the printer is not actively printing.
Changing ports around, isolating USB cables to prevent possible EMI, swapping out cables, Adding powered USB hub for just the camera, both etc.
I have also tried running the camera way under spec (resolution, frames etc.) but that hasn't changed a thing.
Whenever both devices are connected and running at the same time, there is a high change the print will fail with the error. I have spent 4 days trying for a solution, the error has apparently happened to many Raspberry owners over the years, but I have not found a definitve answer as to WHY it is happening. To me it seems like the Pi just axes the USB controller when there is "too much" bandwidth used, but really the camera shouldn't be such an extreme bandwidth-consumer.
As of right now I am going to try a Pi4 I also have, seeing as it has multiple USB controllers to maybe isolate it somewhat through that. But really that's no solution, as there is no power issue and I can't understand the problem.
DMESG
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.63-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1459 SMP Wed Oct 6 16:41:10 BST 2021
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[    0.000000] random: fast init done
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x34000000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x0000000037ffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000037ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000037ffffff]
[    0.000000] On node 0 totalpages: 229376
[    0.000000]   DMA zone: 2016 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 229376 pages, LIFO batch:63
[    0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
[    0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 227360
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5fac3658-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] Kernel parameter elevator= does not have any effect anymore.
               Please use sysfs to set IO scheduler for individual devices.
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 826024K/917504K available (10240K kernel code, 1312K rwdata, 2948K rodata, 1024K init, 863K bss, 25944K reserved, 65536K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 32054 entries in 63 pages
[    0.000000] ftrace: allocated 63 pages with 6 groups
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=1
[    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000025] Switching to timer-based delay loop, resolution 52ns
[    0.000313] Console: colour dummy device 80x30
[    0.001174] printk: console [tty1] enabled
[    0.001241] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001300] pid_max: default: 32768 minimum: 301
[    0.001525] LSM: Security Framework initializing
[    0.001784] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.001834] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.003316] cgroup: Disabling memory control group subsystem
[    0.003600] CPU: Testing write buffer coherency: ok
[    0.004121] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005384] Setting up static identity map for 0x100000 - 0x10003c
[    0.005595] rcu: Hierarchical SRCU implementation.
[    0.006544] smp: Bringing up secondary CPUs ...
[    0.007734] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.009018] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.010363] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.010521] smp: Brought up 1 node, 4 CPUs
[    0.010575] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.010606] CPU: All CPU(s) started in HYP mode.
[    0.010633] CPU: Virtualization extensions available.
[    0.011636] devtmpfs: initialized
[    0.029330] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.029659] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.029721] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.032967] pinctrl core: initialized pinctrl subsystem
[    0.034191] NET: Registered protocol family 16
[    0.038443] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.044174] audit: initializing netlink subsys (disabled)
[    0.044489] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[    0.045094] thermal_sys: Registered thermal governor 'step_wise'
[    0.046076] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.046139] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.046452] Serial: AMBA PL011 UART driver
[    0.064715] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.080152] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-10-29T10:50:02, variant start_x
[    0.090163] raspberrypi-firmware soc:firmware: Firmware hash is b8a114e5a9877e91ca8f26d1a5ce904b2ad3cf13
[    0.134427] Kprobes globally optimized
[    0.139448] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[    0.141755] SCSI subsystem initialized
[    0.142023] usbcore: registered new interface driver usbfs
[    0.142122] usbcore: registered new interface driver hub
[    0.142214] usbcore: registered new device driver usb
[    0.144198] clocksource: Switched to clocksource arch_sys_counter
[    1.916771] VFS: Disk quotas dquot_6.6.0
[    1.916916] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.917142] FS-Cache: Loaded
[    1.917441] CacheFiles: Loaded
[    1.928278] NET: Registered protocol family 2
[    1.928581] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.930123] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.930294] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.930440] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.930653] TCP: Hash tables configured (established 8192 bind 8192)
[    1.930852] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.930930] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.931278] NET: Registered protocol family 1
[    1.932271] RPC: Registered named UNIX socket transport module.
[    1.932308] RPC: Registered udp transport module.
[    1.932337] RPC: Registered tcp transport module.
[    1.932365] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.934066] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    1.938090] Initialise system trusted keyrings
[    1.938396] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    1.947997] zbud: loaded
[    1.950095] FS-Cache: Netfs 'nfs' registered for caching
[    1.950980] NFS: Registering the id_resolver key type
[    1.951051] Key type id_resolver registered
[    1.951080] Key type id_legacy registered
[    1.951256] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.951292] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.952517] Key type asymmetric registered
[    1.952550] Asymmetric key parser 'x509' registered
[    1.952625] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    1.952665] io scheduler mq-deadline registered
[    1.952695] io scheduler kyber registered
[    1.956342] bcm2708_fb soc:fb: FB found 1 display(s)
[    1.971099] Console: switching to colour frame buffer device 90x30
[    1.979792] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 720x480
[    1.988300] bcm2835-rng 3f104000.rng: hwrng registered
[    1.991673] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    1.998772] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    2.014442] brd: module loaded
[    2.029919] loop: module loaded
[    2.034896] Loading iSCSI transport class v2.0-870.
[    2.039620] libphy: Fixed MDIO Bus: probed
[    2.042989] usbcore: registered new interface driver lan78xx
[    2.046258] usbcore: registered new interface driver smsc95xx
[    2.049324] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    2.780661] Core Release: 2.80a
[    2.783749] Setting default values for core params
[    2.786862] Finished setting default values for core params
[    2.990309] Using Buffer DMA mode
[    2.993270] Periodic Transfer Interrupt Enhancement - disabled
[    2.996326] Multiprocessor Interrupt Enhancement - disabled
[    2.999390] OTG VER PARAM: 0, OTG VER FLAG: 0
[    3.002402] Dedicated Tx FIFOs mode
[    3.005914] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b4114000 dma = 0xf4114000 len=9024
[    3.014820] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    3.029211] dwc_otg: Microframe scheduler enabled
[    3.029287] WARN::hcd_init_fiq:457: FIQ on core 1
[    3.034462] WARN::hcd_init_fiq:458: FIQ ASM at 807c9984 length 36
[    3.039675] WARN::hcd_init_fiq:497: MPHI regs_base at b8810000
[    3.044975] dwc_otg 3f980000.usb: DWC OTG Controller
[    3.047765] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    3.050614] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[    3.053409] Init: Port Power? op_state=1
[    3.056160] Init: Power Port (0)
[    3.059192] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    3.064736] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.067667] usb usb1: Product: DWC OTG Controller
[    3.070548] usb usb1: Manufacturer: Linux 5.10.63-v7+ dwc_otg_hcd
[    3.073482] usb usb1: SerialNumber: 3f980000.usb
[    3.077215] hub 1-0:1.0: USB hub found
[    3.080115] hub 1-0:1.0: 1 port detected
[    3.084053] dwc_otg: FIQ enabled
[    3.084067] dwc_otg: NAK holdoff enabled
[    3.084079] dwc_otg: FIQ split-transaction FSM enabled
[    3.084097] Module dwc_common_port init
[    3.084447] usbcore: registered new interface driver usb-storage
[    3.087592] mousedev: PS/2 mouse device common for all mice
[    3.091595] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    3.097531] sdhci: Secure Digital Host Controller Interface driver
[    3.100484] sdhci: Copyright(c) Pierre Ossman
[    3.103998] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[    3.107804] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[    3.111096] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.116082] ledtrig-cpu: registered to indicate activity on CPUs
[    3.119594] hid: raw HID events driver (C) Jiri Kosina
[    3.122829] usbcore: registered new interface driver usbhid
[    3.125953] usbhid: USB HID core driver
[    3.134247] Initializing XFRM netlink socket
[    3.137330] NET: Registered protocol family 17
[    3.140459] Key type dns_resolver registered
[    3.144050] Registering SWP/SWPB emulation handler
[    3.147230] registered taskstats version 1
[    3.150163] Loading compiled-in X.509 certificates
[    3.153915] Key type ._fscrypt registered
[    3.156706] Key type .fscrypt registered
[    3.159382] Key type fscrypt-provisioning registered
[    3.173943] uart-pl011 3f201000.serial: cts_event_workaround enabled
[    3.176891] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[    3.185026] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    3.189765] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    3.192802] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[    3.204357] Indeed it is in host mode hprt0 = 00021501
[    3.281795] sdhost: log_buf @ (ptrval) (f4113000)
[    3.321962] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    3.326630] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.331108] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.336785] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    3.339419] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    3.345259] of_cfs_init
[    3.348047] of_cfs_init: OK
[    3.351570] Waiting for root device PARTUUID=5fac3658-02...
[    3.424237] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    3.426968] Indeed it is in host mode hprt0 = 00001101
[    3.497511] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.500905] mmc1: new high speed SDIO card at address 0001
[    3.505257] mmc0: new high speed SDHC card at address aaaa
[    3.508881] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    3.518107]  mmcblk0: p1 p2
[    3.539464] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.545189] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    3.558975] devtmpfs: mounted
[    3.569218] Freeing unused kernel memory: 1024K
[    3.604742] Run /sbin/init as init process
[    3.607367]   with arguments:
[    3.607379]     /sbin/init
[    3.607390]   with environment:
[    3.607401]     HOME=/
[    3.607412]     TERM=linux
[    3.674649] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[    3.680216] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.683971] hub 1-1:1.0: USB hub found
[    3.687001] hub 1-1:1.0: 4 ports detected
[    4.004270] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    4.144662] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[    4.151072] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.155311] hub 1-1.1:1.0: USB hub found
[    4.158855] hub 1-1.1:1.0: 3 ports detected
[    4.201679] systemd[1]: System time before build time, advancing clock.
[    4.254306] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[    4.343563] NET: Registered protocol family 10
[    4.348326] Segment Routing with IPv6
[    4.388007] usb 1-1.2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[    4.403573] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    4.407198] usb 1-1.2: Product: USB Serial
[    4.468332] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    4.480547] systemd[1]: Detected architecture arm.
[    4.484290] usb 1-1.1.3: new high-speed USB device number 5 using dwc_otg
[    4.552024] systemd[1]: Set hostname to <octopi>.
[    4.625588] usb 1-1.1.3: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.04
[    4.633406] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.637754] usb 1-1.1.3: Product: 4-Port USB 2.0 Hub
[    4.642065] usb 1-1.1.3: Manufacturer: Generic
[    4.667652] hub 1-1.1.3:1.0: USB hub found
[    4.673506] hub 1-1.1.3:1.0: 4 ports detected
[    4.984282] usb 1-1.1.1: new high-speed USB device number 6 using dwc_otg
[    5.114962] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[    5.121928] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    5.214395] usb 1-1.1.3.3: new high-speed USB device number 7 using dwc_otg
[    5.351374] usb 1-1.1.3.3: New USB device found, idVendor=337b, idProduct=090c, bcdDevice= 0.04
[    5.358499] usb 1-1.1.3.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    5.362174] usb 1-1.1.3.3: Product: HBVCAM 5M-AF
[    5.391053] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[    5.400188] libphy: lan78xx-mdiobus: probed
[    5.425740] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[    5.488915] random: systemd: uninitialized urandom read (16 bytes read)
[    5.509476] random: systemd: uninitialized urandom read (16 bytes read)
[    5.514301] systemd[1]: Listening on udev Control Socket.
[    5.522204] random: systemd: uninitialized urandom read (16 bytes read)
[    5.528131] systemd[1]: Created slice User and Session Slice.
[    5.535829] systemd[1]: Reached target Slices.
[    5.544298] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    5.557054] systemd[1]: Listening on Journal Socket (/dev/log).
[    5.565933] systemd[1]: Listening on Journal Socket.
[    5.574757] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    6.319089] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    6.434445] systemd-journald[115]: Received request to flush runtime journal from PID 1
[    7.111804] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    7.120907] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    7.120941] [vc_sm_connected_init]: start
[    7.130432] [vc_sm_connected_init]: installed successfully
[    7.133288] mc: Linux media interface: v0.10
[    7.171970] videodev: Linux video capture interface: v2.00
[    7.219739] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    7.253891] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    7.266263] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[    7.268054] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    7.306406] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    7.378372] bcm2835_audio bcm2835_audio: card created with 8 channels
[    7.616984] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    7.797355] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    7.886771] brcmfmac: F1 signature read @0x18000000=0x15264345
[    7.896373] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    7.898324] usbcore: registered new interface driver brcmfmac
[    7.910818] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    7.910888] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    7.911540] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[    7.912262] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[    7.913384] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[    7.914120] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[    7.914154] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    7.916944] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    7.916984] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    7.917006] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    7.917259] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    7.917301] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    7.917920] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[    7.929881] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    7.929936] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    7.949143] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[    7.949199] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[    7.982979] usbcore: registered new interface driver usbserial_generic
[    7.983074] usbserial: USB Serial support registered for generic
[    7.993699] usbcore: registered new interface driver ch341
[    7.993789] usbserial: USB Serial support registered for ch341-uart
[    7.993921] ch341 1-1.2:1.0: ch341-uart converter detected
[    7.998927] usb 1-1.2: ch341-uart converter now attached to ttyUSB0
[    7.999926] uvcvideo: Found UVC 1.00 device HBVCAM 5M-AF (337b:090c)
[    8.027086] input: HBVCAM 5M-AF: HBVCAM 5M-AF as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.0/input/input0
[    8.027602] usbcore: registered new interface driver uvcvideo
[    8.027617] USB Video Class driver (1.1.1)
[    8.216959] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    8.217105] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    8.226552] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[   10.054114] uart-pl011 3f201000.serial: no DMA platform data
[   10.150008] random: crng init done
[   10.150034] random: 7 urandom warning(s) missed due to ratelimiting
[   10.359509] 8021q: 802.1Q VLAN Support v1.8
[   10.444342] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[   10.707362] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[   11.068378] 8021q: adding VLAN 0 to HW filter on device eth0
[   16.218357] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   17.160850] Bluetooth: Core ver 2.22
[   17.161207] NET: Registered protocol family 31
[   17.161257] Bluetooth: HCI device and connection manager initialized
[   17.161352] Bluetooth: HCI socket layer initialized
[   17.161419] Bluetooth: L2CAP socket layer initialized
[   17.161544] Bluetooth: SCO socket layer initialized
[   17.178578] Bluetooth: HCI UART driver ver 2.3
[   17.178602] Bluetooth: HCI UART protocol H4 registered
[   17.178711] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   17.178970] Bluetooth: HCI UART protocol Broadcom registered
[   17.471749] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   17.471761] Bluetooth: BNEP filters: protocol multicast
[   17.471779] Bluetooth: BNEP socket layer initialized
[  888.883026] ch341-uart ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[  888.883119] ch341-uart ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[  888.897267] usb 1-1.2: USB disconnect, device number 4
[  888.897764] usb 1-1.2: failed to send control message: -19
[  888.898335] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[  888.898427] ch341 1-1.2:1.0: device disconnected
[  891.753460] usb 1-1.2: new full-speed USB device number 8 using dwc_otg
[  891.886528] usb 1-1.2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[  891.886556] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[  891.886572] usb 1-1.2: Product: USB Serial
[  891.888010] ch341 1-1.2:1.0: ch341-uart converter detected
[  891.892909] usb 1-1.2: ch341-uart converter now attached to ttyUSB0
[ 1997.511230] usb usb1-port1: disabled by hub (EMI?), re-enabling...
[ 1997.511270] usb 1-1: USB disconnect, device number 2
[ 1997.511292] usb 1-1.1: USB disconnect, device number 3
[ 1997.511312] usb 1-1.1.1: USB disconnect, device number 6
[ 1997.511758] lan78xx 1-1.1.1:1.0 eth0: Failed to read register index 0x00000120. ret = -19
[ 1997.511799] lan78xx 1-1.1.1:1.0 eth0: Failed to read register index 0x00000120. ret = -19
[ 1997.511828] lan78xx 1-1.1.1:1.0 eth0: Failed to read register index 0x00000120. ret = -19
[ 1997.511857] lan78xx 1-1.1.1:1.0 eth0: Failed to read register index 0x00000098. ret = -19
[ 1997.511877] lan78xx 1-1.1.1:1.0 eth0: Failed to write register index 0x00000098. ret = -19
[ 1997.512027] lan78xx 1-1.1.1:1.0 eth0: Failed to read register index 0x00000098. ret = -19
[ 1997.512048] lan78xx 1-1.1.1:1.0 eth0: Failed to write register index 0x00000098. ret = -19
[ 1997.513314] lan78xx 1-1.1.1:1.0 eth0 (unregistering): Failed to read register index 0x00000024. ret = -19
[ 1997.554036] usb 1-1.1.3: USB disconnect, device number 5
[ 1997.554067] usb 1-1.1.3.3: USB disconnect, device number 7
[ 1997.708026] usb 1-1.2: USB disconnect, device number 8
[ 1997.708768] WARN::dwc_otg_hcd_urb_dequeue:639: Timed out waiting for FSM NP transfer to complete on 4
[ 1997.708872] usb 1-1.2: failed to send control message: -19
[ 1997.709367] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[ 1997.709453] ch341 1-1.2:1.0: device disconnected
[ 1997.911196] Indeed it is in host mode hprt0 = 00001501
[ 1998.121096] usb 1-1: new high-speed USB device number 9 using dwc_otg
[ 1998.121262] Indeed it is in host mode hprt0 = 00001101
[ 1998.361208] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 1998.361219] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1998.361691] hub 1-1:1.0: USB hub found
[ 1998.361752] hub 1-1:1.0: 4 ports detected
[ 1998.681071] usb 1-1.1: new high-speed USB device number 10 using dwc_otg
[ 1998.811446] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 1998.811469] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1998.812411] hub 1-1.1:1.0: USB hub found
[ 1998.812545] hub 1-1.1:1.0: 3 ports detected
[ 1998.911259] usb 1-1.2: new full-speed USB device number 11 using dwc_otg
[ 1999.044218] usb 1-1.2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 1999.044242] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1999.044257] usb 1-1.2: Product: USB Serial
[ 1999.045313] ch341 1-1.2:1.0: ch341-uart converter detected
[ 1999.047538] usb 1-1.2: ch341-uart converter now attached to ttyUSB0
[ 1999.141063] usb 1-1.1.3: new high-speed USB device number 12 using dwc_otg
[ 1999.281395] usb 1-1.1.3: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.04
[ 1999.281416] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1999.281431] usb 1-1.1.3: Product: 4-Port USB 2.0 Hub
[ 1999.281446] usb 1-1.1.3: Manufacturer: Generic
[ 1999.282353] hub 1-1.1.3:1.0: USB hub found
[ 1999.285150] hub 1-1.1.3:1.0: 4 ports detected
[ 1999.591033] usb 1-1.1.1: new high-speed USB device number 13 using dwc_otg
[ 1999.721282] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[ 1999.721292] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1999.831038] usb 1-1.1.3.3: new high-speed USB device number 14 using dwc_otg
[ 1999.965638] usb 1-1.1.3.3: New USB device found, idVendor=337b, idProduct=090c, bcdDevice= 0.04
[ 1999.965651] usb 1-1.1.3.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1999.965657] usb 1-1.1.3.3: Product: HBVCAM 5M-AF
[ 1999.966907] uvcvideo: Found UVC 1.00 device HBVCAM 5M-AF (337b:090c)
[ 1999.984872] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[ 1999.986260] libphy: lan78xx-mdiobus: probed
[ 2000.000083] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[ 2000.100669] input: HBVCAM 5M-AF: HBVCAM 5M-AF as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.0/input/input1
[ 2000.205583] 8021q: adding VLAN 0 to HW filter on device eth0
webcamd.log
1.7.2, 0.18.0, respectively. Running on RPi 3B+
Hmm - there's two issues here that are almost exactly the same, I personally have not seen it before which seems strange. Have you done sudo apt upgrade recently that it might be an issue with a new firmware or something? You only have one webcam, the other poster had 3 - what resolution/FPS is it running at?
I've had this on my rpi before, and it's usually due to one of the USB connections not making a good connection, such as one of the connectors not being plugged in all the way or just fitting loosely in the plug. Vibrations or even just touching the cable can cause the connector to shift a bit, which I imagine causes the pins to connect/disconnect intermittently.
The fun part is that it could be any device on the hub and it will take everything down; in my case one printer was taking down both printers and a USB camera. I found that if I was using the SDcard in the printer (updating firmware) I was bumping that USB connection since it was so close and eventually enough vibration was caused during printing to cause this issue.
My fix was to completely unplug the printer from USB if I needed to use the sdcard slot at all, and then plug it back in afterward.
I have done upgrades afterwards trying to see if there was a fix, however I can not say for certain wheter I recently did upgrades prior to the first occurrence, but it is possible.
Welp, RPi4B+ doesn't seem to have the issue in the exact same setup.
The Pi 4 does have different USB tech to the rest of the lineup, maybe it's more resilient.
