Usb web camera stops randomly during the print
usb web camera stops randomly during the print.
tried ,
sudo pkill mjpg_streamer
and
while true; do if sudo service webcamd status | grep timeout > /dev/null; then echo "starting"; sudo systemctl restart webcamd; fi; sleep 15; done
did not run safe mode dont know actually what is it
Version 0.18.0, running on Raspberry Pi 4 Model B Rev 1.1
octoprint (1).log (519.8 KB)
plugin_octolapse.log (16.2 KB)
also
when i type "cat /var/log/webcamd.log"
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 1080x720 -f 10 -y
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video2
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Feb 19 12:04:44 root: Starting USB webcam
  • It seems that you don't have VL805 (Raspberry Pi 4).
    Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 1080x720 -f 10 -y -d /dev/video0
    i: Desired Resolution: 1080 x 720
    i: Frames Per Second.: 10
    i: Format............: YUYV
    i: JPEG Quality......: 80
    i: The specified resolution is unavailable, using: width 1280 height 720 instead
    o: HTTP Listen Address..: 127.0.0.1
    libv4l2: error turning on stream: Protocol error
    Unable to start capture: Protocol error
    i: Can't enable video in first time
    i: cleaning up resources allocated by input thread
Goodbye...
comes out... Thanks for your help!!
