# Defaults to auto
#camera="auto"
### Additional options to supply to MJPG Streamer for the USB camera
# See https://faq.octoprint.org/mjpg-streamer-config for available options
# Defaults to a resolution of 640x480 px and a framerate of 10 fps
camera_usb_options="-d /dev/video1 -r 1280x720 -f 10"
### Additional options to supply to MJPG Streamer for the RasPi Cam
# Defaults to 10fps
#camera_raspi_options="-fps 10"
### Configuration of camera HTTP output
# Usually you should NOT need to change this at all! Only touch if you
# know what you are doing and what the parameters mean.
# Below settings are used in the mjpg-streamer call like this:
# -o "output_http.so -w $camera_http_webroot $camera_http_options"
# Current working directory is the mjpg-streamer base directory.
#camera_http_webroot="./www-octopi"
#camera_http_options="-n"
Driver Info:
Driver name : uvcvideo
Card type : HD USB Camera: HD USB Camera
Bus info : usb-0000:01:00.0-1.1
Driver version : 5.10.17
Capabilities : 0x84a00001
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Model : HD USB Camera: HD USB Camera
Serial : Ucamera001
Media version : 5.10.17
Hardware revision: 0x00000310 (784)
Interface Info:
Type : V4L Video
Entity Info:
Name : HD USB Camera: HD USB Camera
Function : V4L2 I/O
Flags : default
Pad 0x01000007 : 0: Sink
Link 0x0200000d: from remote pad 0x100000a of entity 'Processing 2': Data, Enabled, Immutable
Priority: 2
Video input : 0 (Camera 1: ok)
Format Video Capture:
Width/Height : 640/360
Pixel Format : 'MJPG' (Motion-JPEG)
Field : None
Bytes per Line : 0
Size Image : 921600
Colorspace : Default
Transfer Function : Default (maps to Rec. 709)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Crop Capability Video Capture:
Bounds : Left 0, Top 0, Width 640, Height 360
Default : Left 0, Top 0, Width 640, Height 360
Pixel Aspect: 1/1
Selection: crop_default, Left 0, Top 0, Width 640, Height 360, Flags:
Selection: crop_bounds, Left 0, Top 0, Width 640, Height 360, Flags:
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 30.000 (30/1)
Read buffers : 0
brightness 0x00980900 (int) : min=1 max=255 step=1 default=128 value=128
contrast 0x00980901 (int) : min=1 max=255 step=1 default=128 value=128
saturation 0x00980902 (int) : min=1 max=255 step=1 default=128 value=128
