The Problem is that when I start octoprint the camera just works fine. Sometimes for 10-15 min sometimes a few hours but then the stream suddenly stops and I get the loading stream message.
I tried:
-reboot
-safe mode
-reinstalling octopi
-Use of powerd usb hub
webcamd.log (10.7 KB)
syslog.log (1.1 MB)
dmesg.log (22.5 KB)
I am running:
octopi: 0.18.0
octoprint 1.7.3
on a Rpi 3b+
Edit:
After lowering the resoulution and letting it run again I now get different errors when I am running dmesg. For me it seams that it has problems with the USB ports or the driver.
dmesg2.log (33.9 KB)
I digged a little bit deeper and found out that /dev/video0 is no longer there. Instead, the camera seams to stream to /dev/video1 when I now change my mjpeg-streamer configuration to listen on /dev/video1 and restarting the webcamd service the cam is working again.
After a few hours, I get the same problem again. The USB device gets disconnected somehow and then /dev/video1 is not available, but now /dev/video0 is back again. Another side effect of this behavior is that it interrupts the print and the serial connection gets lost which is bad. Long prints are not possible with webcam feed.
