I just installed Octoprint on a Windows 10 Laptop PC. I also installed a USB webcam to use as the streaming device. And I installed Yawcam as the video streaming service.
The issue is that I can't get the stream URL to work. The timelapse URL works fine.
I use http://192.168.1.187:8081 for the stream. If I click "test" it returns a broken link indicator.
However the same link works in the browser on both the local machine running octoprint and on a remote machine on the same network accessing octoprint.
Even if I go to the control tab of octoprint in the box that should contain the stream it says "webcam stream not loaded" and gives the link that is currently configured in the settings (http://192.168.1.187:8081). If I click the link the stream opens just as it should.
I've tried different variations of the link adding "/" & "/video.mjpg" to the end. I even used the built-in laptop webcam and got the same results.
no
N/A
octoprint-systeminfo-20220503141033.zip (6.9 KB)
Windows 10 using Chrome browser on both octoprint host machine and the remote PC (on the same home network).
Brand new install of Octoprint yesterday.
No printer yet but it should be here in a day or two (Ender 3 S1 Pro) and I jut wanted to make sure everything will be ready when it arrives.
Any suggestions would be appreciated.
Thanks in advance!
