2019-10-27 09:52:02,351 - octoprint.startup - INFO - Starting OctoPrint 1.3.12
2019-10-27 09:52:02,351 - octoprint.startup - INFO - ******************************************************************************
2019-10-27 09:52:02,626 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2019-10-27 09:52:03,562 - octoprint.startup - INFO - Blacklist processing done, adding 1 blacklisted plugin versions: roomtemp (any)
2019-10-27 09:52:03,579 - octoprint.plugin.core - INFO - Loading plugins from /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins, /home/jiynn/.octoprint/plugins and installed plugin packages...
2019-10-27 09:52:03,938 - octoprint.plugin.core - INFO - Plugin Pi Support Plugin did not pass check, not loading.
2019-10-27 09:52:03,986 - octoprint.plugin.core - INFO - Plugin RTMP Streamer (0.1.4) is disabled.
2019-10-27 09:52:04,250 - octoprint.plugin.core - INFO - Plugin Bed Visualizer (0.1.10) is disabled.
2019-10-27 09:52:04,255 - octoprint.plugins.octoprint.plugins.discovery - INFO - pybonjour is not installed, Zeroconf Discovery won't be available
2019-10-27 09:52:04,265 - octoprint.plugin.core - INFO - Found 29 plugin(s) providing 27 mixin implementations, 43 hook handlers
2019-10-27 09:52:04,358 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-10-27 09:52:04,367 - octoprint.server - INFO - Intermediary server started
2019-10-27 09:52:04,368 - octoprint.plugin.core - INFO - Loading plugins from /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins, /home/jiynn/.octoprint/plugins and installed plugin packages...
2019-10-27 09:52:04,374 - octoprint.plugin.core - INFO - Plugin Pi Support Plugin did not pass check, not loading.
2019-10-27 09:52:04,425 - octoprint.plugin.core - INFO - Found 29 plugin(s) providing 27 mixin implementations, 43 hook handlers
2019-10-27 09:52:04,436 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/jiynn/.octoprint/uploads...
2019-10-27 09:52:04,564 - octoprint.filemanager.storage - INFO - ... file metadata for /home/jiynn/.octoprint/uploads initialized successfully.
2019-10-27 09:52:04,568 - octoprint.printer.standard - INFO - Using print time estimator provided by PrintTimeGenius
2019-10-27 09:52:04,638 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-10-27 09:52:05,017 - octoprint.util.pip - INFO - Using "/home/jiynn/OctoPrint/venv/bin/python2 -m pip" as command to invoke pip
2019-10-27 09:52:05,385 - octoprint.util.pip - INFO - Version of pip is 19.3
2019-10-27 09:52:05,386 - octoprint.util.pip - INFO - pip installs to /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-10-27 09:52:05,387 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-10-27 09:52:05,408 - octoprint.plugin.core - INFO - Initialized 27 plugin implementation(s)
2019-10-27 09:52:05,416 - octoprint.plugin.core - INFO - 29 plugin(s) registered with the system:
| Action Command Prompt Support (bundled) = /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/announcements
| Anonymous Usage Tracking (bundled) = /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/appkeys
| Backup & Restore (bundled) = /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/backup
| Bed Leveling Wizard (0.2.4) = /home/jiynn/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_bedlevelingwizard
| !Bed Visualizer (0.1.10) = /home/jiynn/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| Change Filament Plugin (0.3.0) = /home/jiynn/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_Change_Filament
| Core Wizard (bundled) = /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/corewizard
| Cost Plugin (0.1.3) = /home/jiynn/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_cost
| Discovery (bundled) = /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/discovery
| DisplayLayerProgress Plugin (1.14.2) = /home/jiynn/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_DisplayLayerProgress
| Error Tracking (bundled) = /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/errortracking
| Filament Manager (0.5.3) = /home/jiynn/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_filamentmanager
| Floating Navbar (0.3.1) = /home/jiynn/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_floatingnavbar
| Force Login (bundled) = /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/forcelogin
| Fullscreen Plugin (0.0.4) = /home/jiynn/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_fullscreen
| Logging (bundled) = /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/logging
| MultiCam (0.2.6) = /home/jiynn/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_multicam
| Navbar Temperature Plugin (0.11) = /home/jiynn/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_navbartemp
| OctoPrint Anywhere (1.0.20) = /home/jiynn/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_anywhere
| Plugin Manager (bundled) = /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/pluginmanager
| Printer Safety Check (bundled) = /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/printer_safety_check
| PrintTimeGenius Plugin (2.0.2) = /home/jiynn/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_PrintTimeGenius
| !RTMP Streamer (0.1.4) = /home/jiynn/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_rtmpstreamer
| Simple Emergency Stop (0.2.5) = /home/jiynn/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_simpleemergencystop
| Software Update (bundled) = /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/softwareupdate
| Themeify (1.2.0) = /home/jiynn/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_themeify
| Virtual Printer (bundled) = /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
2019-10-27 09:52:05,499 - octoprint.environment - INFO - Detected environment is Python 2.7.15 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 2600.0
| ram: 4011978752
| os:
| platform: linux2
| python:
| pip: '19.3'
| version: 2.7.15
| virtualenv: /home/jiynn/OctoPrint/venv
2019-10-27 09:52:05,505 - octoprint.server - INFO - Reset webasset folder /home/jiynn/.octoprint/generated/webassets...
2019-10-27 09:52:05,512 - octoprint.server - INFO - Reset webasset folder /home/jiynn/.octoprint/generated/.webassets-cache...
2019-10-27 09:52:05,871 - octoprint.server - INFO - Shutting down intermediary server...
2019-10-27 09:52:05,876 - octoprint.server - INFO - Intermediary server shut down
2019-10-27 09:52:05,878 - octoprint.events - INFO - Processing startup event, this is our first event
2019-10-27 09:52:05,878 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2019-10-27 09:52:05,881 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-10-27 09:52:05,889 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-10-27 09:52:05,931 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-10-27 09:52:06,033 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2019-10-27 09:52:06,035 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2019-10-27 09:52:06,085 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance "Jiynn's Creality Ender 3 Pro" for SSDP
2019-10-27 09:52:06,098 - octoprint.server - INFO - Listening on http://0.0.0.0:5000 and http://[::]:5000
2019-10-27 09:52:06,140 - tornado.access - WARNING - 404 GET /intermediary.gif?_=1572184325627 (192.168.1.254) 30.43ms
2019-10-27 09:52:06,206 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-10-27 09:52:06,276 - octoprint.server.util.flask - INFO - Passively logging in user jiynn from 192.168.1.254
2019-10-27 09:52:06,342 - tornado.access - WARNING - 404 GET /cached.gif?_=1572184325899 (192.168.1.254) 110.76ms
2019-10-27 09:52:06,400 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.1.254
2019-10-27 09:52:06,474 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-10-27 09:52:06,732 - octoprint.server.util.flask - INFO - Passively logging in user jiynn from 192.168.1.254
2019-10-27 09:52:06,759 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-10-27 09:52:06,802 - octoprint.server.util.sockjs - INFO - User jiynn logged in on the socket from client 192.168.1.254
2019-10-27 09:52:06,836 - octoprint.util.pip - INFO - Using "/home/jiynn/OctoPrint/venv/bin/python2 -m pip" as command to invoke pip
2019-10-27 09:52:06,836 - octoprint.util.pip - INFO - pip installs to /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-10-27 09:52:06,836 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-10-27 09:52:06,950 - octoprint.util.pip - INFO - Using "/home/jiynn/OctoPrint/venv/bin/python2 -m pip" as command to invoke pip
2019-10-27 09:52:07,227 - tornado.access - WARNING - 404 GET /intermediary.gif?_=1572184326889 (192.168.1.254) 4.88ms
2019-10-27 09:52:07,353 - octoprint.server.util.flask - INFO - Passively logging in user jiynn from 192.168.1.254
2019-10-27 09:52:07,367 - tornado.access - WARNING - 404 GET /cached.gif?_=1572184327045 (192.168.1.254) 20.29ms
2019-10-27 09:52:07,584 - tornado.access - WARNING - 409 GET /api/printer (192.168.1.254) 5.00ms
2019-10-27 09:52:08,271 - octoprint.util.pip - INFO - pip installs to /home/jiynn/OctoPrint/venv/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-10-27 09:52:08,271 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-10-27 09:52:08,311 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2019-10-27 09:52:08,323 - py.warnings - WARNING - /home/jiynn/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_anywhere/config.py:53: YAMLLoadWarning: calling yaml.load() without Loader=... is deprecated, as the default Loader is unsafe. Please read https://msg.pyyaml.org/load for full details.
self.__items__ = yaml.load(config_str)
2019-10-27 09:52:08,338 - octoprint.plugins.multicam - INFO - MultiCam Loaded! (more: [{'URL': 'http://104.187.13.173:8080/?action=stream', 'isButtonEnabled': False, 'name': 'Default'}])
2019-10-27 09:52:08,360 - octoprint.plugins.themeify - INFO - Themeify initialized.
2019-10-27 09:52:08,464 - octoprint.server.util.flask - INFO - Passively logging in user jiynn from 192.168.1.254
2019-10-27 09:52:08,477 - tornado.access - WARNING - 404 GET /cached.gif?_=1572184328098 (192.168.1.254) 17.73ms
2019-10-27 09:52:08,502 - octoprint.plugins.anywhere - WARNING - {u'mjpeg_stream_tier': 6, u'UserId': 35588, u'camResolution': u'medium', u'name': u'My First 3D Printer', u'flipV': False, u'octolapseOptedIn': None, u'recordTimelapse': False, u'rotate90N': False, u'token': u'HEVPNKII0EN9KPY3DOX688ISMLSG3S42', u'last$
2019-10-27 09:52:08,583 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://jiynnprint.us.to:5000/'}
2019-10-27 09:52:09,030 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 4}
2019-10-27 09:52:09,078 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.1.254
2019-10-27 09:52:09,274 - octoprint.server.util.flask - INFO - Passively logging in user jiynn from 192.168.1.254
2019-10-27 09:52:09,325 - octoprint.server.util.sockjs - INFO - User jiynn logged in on the socket from client 192.168.1.254
2019-10-27 09:52:09,717 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'python': '2.7.15', 'ram': 4011978752, 'version': u'1.3.12', 'pip': '19.3', 'cores': 4, 'freq': 2600.0, 'os': 'linux'}
2019-10-27 09:52:09,766 - octoprint.server.util.flask - INFO - Passively logging in user jiynn from 192.168.1.254
2019-10-27 09:52:09,785 - tornado.access - WARNING - 404 GET /cached.gif?_=1572184329209 (192.168.1.254) 28.27ms
2019-10-27 09:52:10,418 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {'plugins': u'displaylayerprogress:1.14.2,cost:0.1.3,fullscreen:0.0.4,bedlevelingwizard:0.2.4,themeify:1.2.0,multicam:0.2.6,simpleemergencystop:0.2.5,navbartemp:0.11,change_filament:0.3.0,anywhere:1.0.20,floatingnavbar:$
2019-10-27 09:52:10,851 - octoprint.server.util.flask - INFO - Passively logging in user jiynn from 192.168.1.254
2019-10-27 09:52:10,899 - tornado.access - WARNING - 404 GET /cached.gif?_=1572184330520 (192.168.1.254) 71.86ms
2019-10-27 09:52:12,039 - octoprint.server.util.flask - INFO - Passively logging in user jiynn from 192.168.1.254
2019-10-27 09:52:12,080 - tornado.access - WARNING - 404 GET /cached.gif?_=1572184331637 (192.168.1.254) 53.95ms
2019-10-27 09:52:13,146 - octoprint.server.util.flask - INFO - Passively logging in user jiynn from 192.168.1.254
2019-10-27 09:52:13,169 - tornado.access - WARNING - 404 GET /cached.gif?_=1572184332830 (192.168.1.254) 28.07ms
2019-10-27 09:52:13,691 - octoprint.server.preemptive_cache - INFO - ... done in 5.11s
2019-10-27 09:52:13,691 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.1.79/'}
2019-10-27 09:52:14,203 - octoprint.server.util.flask - INFO - Passively logging in user jiynn from 192.168.1.254
2019-10-27 09:52:14,212 - octoprint.server.views - INFO - Found path / in cache (key: ui:_default:http://jiynnprint.us.to:5000/:en), signaling as cached
2019-10-27 09:52:14,300 - octoprint.server.util.flask - INFO - Passively logging in user jiynn from 192.168.1.254
2019-10-27 09:52:15,932 - octoprint.server.preemptive_cache - INFO - ... done in 2.24s
2019-10-27 09:52:18,719 - tornado.access - WARNING - 409 GET /api/printer (192.168.1.254) 9.56ms
2019-10-27 09:52:24,609 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.1.254
2019-10-27 09:52:24,752 - octoprint.server.util.flask - INFO - Passively logging in user jiynn from 192.168.1.254
2019-10-27 09:52:25,725 - octoprint.server.util.sockjs - INFO - User jiynn logged in on the socket from client 192.168.1.254
2019-10-27 09:52:27,647 - tornado.access - WARNING - 409 GET /api/printer (192.168.1.254) 2.89ms
2019-10-27 09:52:33,982 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2019-10-27 09:52:34,005 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2019-10-27 09:52:34,008 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2019-10-27 09:52:34,013 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-10-27 09:52:34,016 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-10-27 09:52:34,248 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-10-27 09:52:37,807 - tornado.access - WARNING - 409 GET /api/printer (192.168.1.254) 2.16ms
2019-10-27 09:52:41,591 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2019-10-27 09:52:41,593 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-10-27 09:52:41,643 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin Creality 3D"
2019-10-27 09:52:41,677 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2019-10-27 09:52:42,391 - octoprint.plugins.tracking - INFO - Sent tracking event printer_connected, payload: {u'printer_baudrate': 115200, u'printer_port': u'AUTO', 'firmware_name': 'Marlin Creality 3D'}
2019-10-27 09:56:45,886 - octoprint.server.util.sockjs - INFO - Client connection closed: 192.168.1.254
2019-10-27 09:56:45,892 - octoprint.server.util.sockjs - INFO - Client connection closed: 192.168.1.254
2019-10-27 09:56:45,935 - octoprint.server - INFO - Shutting down...
2019-10-27 09:56:46,160 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2019-10-27 09:56:46,161 - octoprint.events - INFO - Event loop shut down
2019-10-27 09:56:46,170 - octoprint.server - INFO - Goodbye!
