I am not getting an alert when PrintPause happens through IFTTT plugin when the print pauses due to filament run out. I am having this issue on two instances. The first one is Neptune 3 Max and its factory stock filament detector. I am only using OctoPrint-IFTTT for that one. For the Ender 5 I am using a Pi based filament run out detector and Filament Sensor Simplified to monitor and react.
I have tried using the Octoprint pause on the Ender 5 and the M600 pause as well. in the Filament Sensor Simplified plugin. I have monitored that the pause is reflected in the Octoprint interface. I have paused using the pause button in the software and also do not get an alert. I did try the Webhook IFTTT URL directly and that worked.
I would like to use IFTTT as I am already using it for other things in my house If there are other options, I am willing to try them as well.
Yes
octoprint-systeminfo-20231007153128.zip (257.5 KB)
- OctoPrint: 1.9.2
- Camera Settings: 0.4.3
- Cost Estimation: 3.5.0
- Cura Thumbnails: 1.0.2
- Dashboard Plugin: 1.19.10
- DisplayLayerProgress Plugin: 1.28.0
- File Check Plugin: 2021.2.23
- Firmware Check Plugin: 2021.10.11
- OctoPrint-IFTTT: 1.4.1
- Pi Support Plugin: 2023.7.31
- Preheat Button: 0.8.0
- PrintJobHistory Plugin: 1.17.0
- Slicer Thumbnails: 1.0.3
- SpoolManager Plugin: 1.7.0
- Timelapse+: 1.4.1
The challenge is not browser or OS dependent for me.
