Using unity, printer using octoprint send manual commands
I'm using a vr setup to display a digital twin of a printer, using octoprint to send code to the printers and display information (all works besides this movement commands). The logs state that it receives and confirms the movement, the printer however does not move. In the web api it works perfectly fine and the GCode commands seem identical.
Checked terminal for missing commands, restarted octoprint, check unity code for issues
yes
no
octoprint-systeminfo-20240920105955.zip (123.8 KB)
Lulzbot Taz Workhorse, Windows
How are you handling the splitting of the commands to two 'devices'?
How are you handling the two responses?
using System.Collections;
using System.Net.Http;
using UnityEngine;
using UnityEngine.UI;
using TMPro;
using System.Threading.Tasks;
public class SendMovementCommand : MonoBehaviour
    public Button buttonPosX;
    public Button buttonNegX;
    public Button buttonPosY;
    public Button buttonNegY;
    public Button buttonPosZ;
    public Button buttonNegZ;
    public Button homeButton;
    public Button cancelButton;
    public TMP_Text statusText;
    public TMP_Text xyProgressText;
    public TMP_Text zProgressText;
    public TMP_Text confirmationText;
    private HttpClient client;
    private string commandUrl = "http://.../api/printer/command";
    private string apiKey = "...";
    private float currentX = 0f;
    private float currentY = 0f;
    private float currentZ = 0f;
    private bool canSendCommand = true;
    private bool confirmCancel = false;
    private Coroutine cancelCoroutine;
    void Start()
        client = new HttpClient();
        client.DefaultRequestHeaders.Add("X-Api-Key", apiKey);
        buttonPosX.onClick.AddListener(() => MoveAxis("G0 X10", "X", 10));
        buttonNegX.onClick.AddListener(() => MoveAxis("G0 X-10", "X", -10));
        buttonPosY.onClick.AddListener(() => MoveAxis("G0 Y10", "Y", 10));
        buttonNegY.onClick.AddListener(() => MoveAxis("G0 Y-10", "Y", -10));
        buttonPosZ.onClick.AddListener(() => MoveAxis("G0 Z10", "Z", 10));
        buttonNegZ.onClick.AddListener(() => MoveAxis("G0 Z-10", "Z", -10));
        homeButton.onClick.AddListener(HomeAllAxes);
        cancelButton.onClick.AddListener(CancelOrConfirm);
    async void MoveAxis(string gCodeCommand, string axis, float moveAmount)
        Debug.Log($"Attempting to send command: {gCodeCommand}");
        Debug.Log($"Axis: {axis}, Move Amount: {moveAmount}");
        if (!canSendCommand)
            statusText.text = "Please wait for the cooldown period.";
            return;
        canSendCommand = false;
        var commandPayload = new CommandPayload { command = gCodeCommand };
        string jsonPayload = JsonUtility.ToJson(commandPayload);
        Debug.Log($"JSON Payload: {jsonPayload}");
        HttpContent content = new StringContent(jsonPayload, System.Text.Encoding.UTF8, "application/json");
        HttpResponseMessage response = null;
        try
            response = await client.PostAsync(commandUrl, content);
            if (response.IsSuccessStatusCode)
                Debug.Log($"Command {gCodeCommand} sent successfully.");
                if (axis == "X")
                    currentX += moveAmount;
                    xyProgressText.text = $"X Axis Position: {currentX}";
                else if (axis == "Y")
                    currentY += moveAmount;
                    xyProgressText.text = $"Y Axis Position: {currentY}";
                else if (axis == "Z")
                    currentZ += moveAmount;
                    zProgressText.text = $"Z Axis Position: {currentZ}";
                statusText.text = $"Command {gCodeCommand} sent successfully.";
            else
                string errorContent = await response.Content.ReadAsStringAsync();
                Debug.LogError($"Failed to send command {gCodeCommand}. Response: {response.StatusCode}, {errorContent}");
                statusText.text = $"Failed to send command {gCodeCommand}. Response: {response.StatusCode}, {errorContent}";
        catch (HttpRequestException e)
            Debug.LogError($"Request error: {e.Message}");
            statusText.text = $"Request error: {e.Message}";
        await Cooldown(2);
        statusText.text = "Ready for next command.";
    async void HomeAllAxes()
            return;
        var commandPayload = new CommandPayload { command = "G28" };
        Debug.Log($"Sending home command: G28");
        try
                currentX = 0f;
                currentY = 0f;
                currentZ = 0f;
                xyProgressText.text = "X/Y Axis Position: 0";
                zProgressText.text = "Z Axis Position: 0";
                statusText.text = "Home command sent successfully.";
            else
                Debug.LogError($"Failed to send home command. Response: {response.StatusCode}, {errorContent}");
                statusText.text = $"Failed to send home command. Response: {response.StatusCode}, {errorContent}";
        await Cooldown(2);
    void CancelOrConfirm()
        if (confirmCancel)
            CancelObject();
            if (cancelCoroutine != null)
                StopCoroutine(cancelCoroutine);
                confirmationText.text = ""; // Clear the confirmation text
        else
            confirmationText.text = "Are you sure you want to cancel the print? Press again to confirm.";
            confirmCancel = true;
            cancelCoroutine = StartCoroutine(ResetCancelConfirmation());
    async void CancelObject()
        string gCodeCommand = "M486 C";  // Assuming this command cancels the current print
        Debug.Log($"Sending cancel command: M486 C");
        try
                statusText.text = $"Print cancelled successfully.";
            else
                statusText.text = $"Failed to cancel print. Response: {response.StatusCode}, {errorContent}";
        await Cooldown(2);
    IEnumerator ResetCancelConfirmation()
        yield return new WaitForSeconds(5);
        confirmationText.text = ""; // Clear the confirmation text after 5 seconds
    async Task Cooldown(int seconds)
        for (int i = seconds; i > 0; i--)
            statusText.text = $"Cooldown: {i} seconds";
            await Task.Delay(1000);
    void OnDestroy()
        if (client != null)
            client.Dispose();
[System.Serializable]
public class CommandPayload
    public string command;
I have two versions of this script for the printers (plan to merge them once fixed). This code works perfectly for the home command but others have issue (the up button for the y axis doesnt work, most buttons only respond to one press, the second press is ignored only by the actual printers movement, and the z axis will move until it hits the bed).
Maybe I am misunderstanding something. First turn on the serial logging. I want to see what you are sending to the printer and what is sends back. Next... so you are making a VR UI for OctoPrint? And not a VR printer?
serial.log (20.6 KB)
It's a digital twin of the printer (so more so a VR UI for the printer, it just displays what's happening in the VR headspace as well.)
