V1.3 camera not working
Pi Cam 1.3
Red light is on but no image
Reinstalled Octprint multiple times, tried changing resolution, tried adding -y, changed to 128 mem split, enable in raspi-config
Webcam log doesnt exist
Octoprint version 1.4
Octopi Version 0.17.0
Pi 3B+
pi@octopi:~ $ vcgencmd get_camera
supported=1 detected=1
Tried
pi@octopi:~ $ sudo apt-get install autoconf gettext libtool libjpeg62-dev
[sudo] password for pi:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libjpeg62-dev : Depends: libjpeg62 (= 1:6b2-2)
E: Unable to correct problems, you have held broken packages.
Just to be sure - here my picam checklist
  • Is the CSI cable inserted the right way? The silvery contacts need to face away from the Ethernet connector!
  • Is the CSI cable fully seated?
  • Did you insert the CSI cable into the Display connector? It needs to be inserted into the CSI connector, which is the one closer to the Ethernet connector.
  • Is the other end of the CSI cable correctly attached to the camera board?
Did the camera work before?
yes if it wasnt the red light wouldnt be on and no its brand new never worked
Old usb cams work
You might consider installing what it's looking for:
sudo apt-get install libjpeg62
Or maybe:
mkdir ~/tmp
cd ~/tmp
git clone https://github.com/LuaDist/libjpeg.git
cd libj*
./configure
make
make install
cd ~
rm -Rf ~/tmp
sudo reboot
double checked cam was turned on in raspi-config
double checked mem set to 128
sudo reboot
pi@octopi:~ $ raspistill -o cam.jpg
Camera control callback cmd=0x4f525245mmal: No data received from sensor. Check all connections, including the Sunny one on the camera board
Ran apt-get update && upgrade and rpi-update still just freezes the Pi during camera
Duff camera? I had this about a week ago. Swapped the camera with one I was using on another project and it worked straight away.
I gave up, Ill just get a USB Camera and be done with it, spent to much wasted time on something that should work.
