pi@octopi2021:~ $ groups pi
pi : pi adm tty dialout cdrom sudo audio video plugdev games users input netdev spi i2c gpio
Not yet.
TBD.
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:97.0) Gecko/20100101 Firefox/97.0
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 3971153920
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.2
env.python.pip: 22.0.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.7.3
printer.firmware: Marlin TH3D UFW 2.38 (Feb 3 2022 21:58:07)
octoprint.log:
2022-03-02 15:29:11,263 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2022-03-02 15:31:17,449 - octoprint.plugins.softwareupdate - INFO - Starting update of pi_support to 2022.3.1...
2022-03-02 15:31:21,427 - octoprint.plugins.softwareupdate - ERROR - Update of pi_support can not be performed, please also check plugin_softwareupdate_console.log for possible causes of this
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate/init.py", line 2090, in _perform_update
target, populated_check, target_version, log_cb=self._log, online=online
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate/updaters/pip.py", line 115, in perform_update
returncode, stdout, stderr = pip_caller.execute(*pip_args, **pip_kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/pip.py", line 208, in execute
return self.call(command, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/commandline.py", line 244, in call
all_stdout += process_stdout(p.stdout.readlines(timeout=0.5))
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/commandline.py", line 236, in process_stdout
return process_lines(lines, self._log_stdout)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/commandline.py", line 230, in process_lines
*map(lambda x: to_unicode(x, errors="replace"), lines)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/pip.py", line 498, in _preprocess_lines
return list(map(self._preprocess, lines))
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/pip.py", line 517, in _preprocess
return to_unicode(clean_ansi(text))
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/commandline.py", line 57, in clean_ansi
return _ANSI_REGEX.sub(b"", line.encode("latin1")).decode("latin1")
UnicodeEncodeError: 'latin-1' codec can't encode characters in position 5-44: ordinal not in range(256)
2022-03-02 15:31:21,492 - octoprint.plugins.softwareupdate - INFO - Saved update log to disk
2022-03-02 15:33:27,731 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2022-03-02 15:33:28,810 - octoprint.plugins.camerasettings - INFO - Excluding camera bcm2835-isp-capture0 based on ^bcm2835-isp-\w+
2022-03-02 15:33:28,812 - octoprint.plugins.camerasettings - INFO - Excluding camera bcm2835-codec-isp based on ^bcm2835-codec-\w+
2022-03-02 15:33:28,843 - octoprint.plugins.camerasettings - INFO - Excluding camera bcm2835-codec-decode based on ^bcm2835-codec-\w+
2022-03-02 15:33:28,845 - octoprint.plugins.camerasettings - INFO - Excluding camera bcm2835-isp-capture1 based on ^bcm2835-isp-\w+
2022-03-02 15:33:28,847 - octoprint.plugins.camerasettings - INFO - Excluding camera bcm2835-isp-output0 based on ^bcm2835-isp-\w+
2022-03-02 15:33:28,848 - octoprint.plugins.camerasettings - INFO - Excluding camera bcm2835-codec-encode based on ^bcm2835-codec-\w+
2022-03-02 15:33:28,881 - octoprint.plugins.camerasettings - INFO - Excluding camera bcm2835-codec-image_fx based on ^bcm2835-codec-\w+
2022-03-02 15:33:28,883 - octoprint.plugins.camerasettings - INFO - Excluding camera bcm2835-isp-stats2 based on ^bcm2835-isp-\w+
2022-03-02 15:38:41,238 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.230
plugin_softwareupdate_console.log:
2022-03-02 15:31:17,454 /home/pi/oprint/bin/python3 -m pip --disable-pip-version-check install https://github.com/OctoPrint/OctoPrint-PiSupport/archive/2022.3.1.zip --no-cache-dir
plugin_softwareupdate_update.log
2022-03-02 15:31:21 - Pi Support Plugin - 2021.10.28 -> 2022.3.1 - FAILED - Update failed (Release notes: Release 2022.3.1 · OctoPrint/OctoPrint-PiSupport · GitHub)
octoprint-systeminfo-20220302154547.zip (68.6 KB)
