FileNotFoundError: [Errno 2] No such file or directory: '/opt/vc/bin/vcgencmd',
Restarted container, restarted OctoPrint. Everytime this restarts within docker, the same error appears in the log.
No, as no known issues, other than the error message are present. All else appears to be working.
N/A
browser.user_agent : Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36
connectivity.connection_check : 8.8.8.8:53
connectivity.connection_ok : True
connectivity.enabled : True
connectivity.online : True
connectivity.resolution_check : octoprint.org
connectivity.resolution_ok : True
env.hardware.cores : 4
env.hardware.freq : 1500.0
env.hardware.ram : 1962061824
env.os.bits : 32
env.os.id : linux
env.os.platform : linux
env.python.pip : 21.2.4
env.python.version : 3.8.12
env.python.virtualenv : False
octoprint.safe_mode : False
octoprint.version : 1.7.2
systeminfo.generator : zipapi
octoprint.log
314.74K chars
3.13K lines
serial.log
148 chars
1 line
plugin_pluginmanager_console.log
91.37K chars
547 lines
plugin_softwareupdate_update.log
0 chars
1 line
OctoPrint V1.7.2
Receiving the following error message within the logs:
2021-12-08 11:28:10,406 - octoprint.plugins.dashboard - INFO - Dashboard started,
2021-12-08 11:28:10,410 - octoprint.JsFrontendErrors(Dash) - INFO - Js Logger (Dash) started,
2021-12-08 11:28:10,584 - octoprint.plugins.octopod - INFO - OctoPod loaded!,
Initializing GcodePositionProcessor V1.0.1 - Copyright (C) 2019 Brad Hochgesang...Python 3+ Detected...complete
2021-12-08 11:28:10,791 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid,
Exception in thread Thread-33:,
Traceback (most recent call last):,
File "/usr/local/lib/python3.8/site-packages/sarge/init.py", line 667, in run,
self.process = p = Popen(self.args, **self.kwargs),
File "/usr/local/lib/python3.8/subprocess.py", line 858, in init,
self.execute_child(args, executable, preexec_fn, close_fds,,
File "/usr/local/lib/python3.8/subprocess.py", line 1704, in execute_child,
Exception in thread Thread-35:,
raise child_exception_type(errno_num, err_msg, err_filename),
During handling of the above exception, another exception occurred:,
File "/usr/local/lib/python3.8/threading.py", line 932, in bootstrap_inner,
self.run(),
File "/usr/local/lib/python3.8/site-packages/octoprint/util/init.py", line 1338, in run,
self.function(*self.args, **self.kwargs),
File "/octoprint/plugins/lib/python3.8/site-packages/octoprint_navbartemp/init.py", line 68, in update_soc_temp,
temp = self.sbc.check_soc_temp(),
File "/octoprint/plugins/lib/python3.8/site-packages/octoprint_navbartemp/libs/sbc.py", line 73, in check_soc_temp,
p = run(self.temp_cmd, stdout=Capture()),
File "/usr/local/lib/python3.8/site-packages/sarge/init.py", line 1480, in run,
self.run(),
p.run(input=input, async=async),
File "/usr/local/lib/python3.8/site-packages/sarge/init.py", line 1087, in run,
File "/octoprint/plugins/lib/python3.8/site-packages/octoprint_octopod/init.py", line 381, in update_soc_temp,
self.run_node(node, input=input, async=False),
File "/usr/local/lib/python3.8/site-packages/sarge/init.py", line 1205, in run_node,
self.soc_temp_notifications.check_soc_temp(self.settings),
File "/octoprint/plugins/lib/python3.8/site-packages/octoprint_octopod/soc_temp_notifications.py", line 32, in check_soc_temp,
result = getattr(self, method)(node, input, async),
File "/usr/local/lib/python3.8/site-packages/sarge/init.py", line 1351, in run_command_node,
temp = float(self.sbc.check_soc_temp()),
File "/octoprint/plugins/lib/python3.8/site-packages/octoprint_octopod/libs/sbc.py", line 79, in check_soc_temp,
node.cmd.run(input=input, async=async),
File "/usr/local/lib/python3.8/site-packages/sarge/init.py", line 670, in run,
raise ValueError('Command not found: %s' % self.args[0]),
ValueError: Command not found: /opt/vc/bin/vcgencmd,
self.run_node(node, input=input, async_=False),
result = getattr(self, method)(node, input, async_),
node.cmd.run(input=input, async_=async_),
