Camera stream just crash randomly when making long prints time-laps.
Since I've already faced video problems with the RPi4 (vlc / omxplayer randomly hang / deadlocks while playing video loops) I've tried to update the RPi4 firmware with sudo rpi-update without any luck.
The only way to solve this for me is to running octoprint from a Raspberry Pi3B+
The only way to make the video stream to load again after a crash is a complete system reboot.
dmesg output:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.31-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1411 SMP Tue Apr 20 10:44:18 BST 2021
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x00000000fbffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] On node 0 totalpages: 999424
[ 0.000000] DMA zone: 2304 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 802816 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50764 r8192 d22964 u81920
[ 0.000000] pcpu-alloc: s50764 r8192 d22964 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 997120
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=DC:A6:32:A3:51:37 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Kernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
[ 0.000000] Memory: 3602304K/3997696K available (10240K kernel code, 1364K rwdata, 3188K rodata, 2048K init, 891K bss, 133248K reserved, 262144K cma-reserved, 3211264K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 34277 entries in 67 pages
[ 0.000000] ftrace: allocated 67 pages with 3 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
[ 0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000035] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000098] bcm2835: system timer (irq = 25)
[ 0.000748] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000769] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000791] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000810] Switching to timer-based delay loop, resolution 18ns
[ 0.001072] Console: colour dummy device 80x30
[ 0.001819] printk: console [tty1] enabled
[ 0.001885] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.001941] pid_max: default: 32768 minimum: 301
[ 0.002118] LSM: Security Framework initializing
[ 0.002319] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002365] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003948] Disabling memory control group subsystem
[ 0.004082] CPU: Testing write buffer coherency: ok
[ 0.004554] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005773] Setting up static identity map for 0x200000 - 0x20003c
[ 0.005989] rcu: Hierarchical SRCU implementation.
[ 0.006932] smp: Bringing up secondary CPUs ...
[ 0.008157] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.009530] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010849] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.011008] smp: Brought up 1 node, 4 CPUs
[ 0.011054] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.011084] CPU: All CPU(s) started in HYP mode.
[ 0.011111] CPU: Virtualization extensions available.
[ 0.011959] devtmpfs: initialized
[ 0.026433] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.026703] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.026758] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.033682] pinctrl core: initialized pinctrl subsystem
[ 0.034754] NET: Registered protocol family 16
[ 0.038835] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.039607] audit: initializing netlink subsys (disabled)
[ 0.039895] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.040448] thermal_sys: Registered thermal governor 'step_wise'
[ 0.041439] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.041494] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.041911] Serial: AMBA PL011 UART driver
[ 0.074071] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.090899] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-04-12T15:53:21, variant start_x
[ 0.100912] raspberrypi-firmware soc:firmware: Firmware hash is 0227a0840ee8c94294cf3b2c4b2d42031a58f05a
[ 0.140646] Kprobes globally optimized
[ 0.145811] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.149967] vgaarb: loaded
[ 0.150417] SCSI subsystem initialized
[ 0.150659] usbcore: registered new interface driver usbfs
[ 0.150735] usbcore: registered new interface driver hub
[ 0.150823] usbcore: registered new device driver usb
[ 0.151558] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.153483] clocksource: Switched to clocksource arch_sys_counter
[ 1.111114] VFS: Disk quotas dquot_6.6.0
[ 1.111236] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.111426] FS-Cache: Loaded
[ 1.111638] CacheFiles: Loaded
[ 1.121795] NET: Registered protocol family 2
[ 1.122833] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.122898] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.122978] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.123061] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.123236] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.123290] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.123639] NET: Registered protocol family 1
[ 1.124394] RPC: Registered named UNIX socket transport module.
[ 1.124428] RPC: Registered udp transport module.
[ 1.124457] RPC: Registered tcp transport module.
[ 1.124485] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.124523] PCI: CLS 0 bytes, default 64
[ 1.127416] Initialise system trusted keyrings
[ 1.127665] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 1.136088] zbud: loaded
[ 1.138318] FS-Cache: Netfs 'nfs' registered for caching
[ 1.139092] NFS: Registering the id_resolver key type
[ 1.139142] Key type id_resolver registered
[ 1.139171] Key type id_legacy registered
[ 1.139310] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.139343] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.140381] Key type asymmetric registered
[ 1.140413] Asymmetric key parser 'x509' registered
[ 1.140619] bounce: pool size: 64 pages
[ 1.140675] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.140918] io scheduler mq-deadline registered
[ 1.140951] io scheduler kyber registered
[ 1.145542] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.145595] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.145696] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.145805] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
[ 1.205622] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.206018] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.206055] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.206090] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.206201] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.206461] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.210000] PCI: bus0: Fast back to back transfers disabled
[ 1.210355] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.210499] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.210950] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.214500] PCI: bus1: Fast back to back transfers disabled
[ 1.214614] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.214656] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.214759] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.214799] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.215217] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 1.215447] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
[ 1.224080] iproc-rng200 fe104000.rng: hwrng registered
[ 1.224405] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.225294] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.237495] brd: module loaded
[ 1.249671] loop: module loaded
[ 1.251335] Loading iSCSI transport class v2.0-870.
[ 1.254648] libphy: Fixed MDIO Bus: probed
[ 1.256370] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.273562] libphy: bcmgenet MII bus: probed
[ 1.353684] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.354844] usbcore: registered new interface driver r8152
[ 1.354929] usbcore: registered new interface driver lan78xx
[ 1.355008] usbcore: registered new interface driver smsc95xx
[ 1.356661] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
[ 1.356841] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.356891] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.360301] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
[ 1.361630] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.361671] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.361707] usb usb1: Product: xHCI Host Controller
[ 1.361738] usb usb1: Manufacturer: Linux 5.10.31-v7l+ xhci-hcd
[ 1.361768] usb usb1: SerialNumber: 0000:01:00.0
[ 1.362540] hub 1-0:1.0: USB hub found
[ 1.362654] hub 1-0:1.0: 1 port detected
[ 1.363336] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.363379] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.363425] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.364021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.364061] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.364097] usb usb2: Product: xHCI Host Controller
[ 1.364127] usb usb2: Manufacturer: Linux 5.10.31-v7l+ xhci-hcd
[ 1.364157] usb usb2: SerialNumber: 0000:01:00.0
[ 1.364874] hub 2-0:1.0: USB hub found
[ 1.364973] hub 2-0:1.0: 4 ports detected
[ 1.366668] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.366994] dwc_otg: FIQ enabled
[ 1.367009] dwc_otg: NAK holdoff enabled
[ 1.367023] dwc_otg: FIQ split-transaction FSM enabled
[ 1.367041] Module dwc_common_port init
[ 1.367489] usbcore: registered new interface driver uas
[ 1.367616] usbcore: registered new interface driver usb-storage
[ 1.367822] mousedev: PS/2 mouse device common for all mice
[ 1.369510] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.373086] sdhci: Secure Digital Host Controller Interface driver
[ 1.373122] sdhci: Copyright(c) Pierre Ossman
[ 1.373948] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.374600] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.378753] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.379114] hid: raw HID events driver (C) Jiri Kosina
[ 1.379323] usbcore: registered new interface driver usbhid
[ 1.379354] usbhid: USB HID core driver
[ 1.385109] Initializing XFRM netlink socket
[ 1.385172] NET: Registered protocol family 17
[ 1.385326] Key type dns_resolver registered
[ 1.385711] Registering SWP/SWPB emulation handler
[ 1.385906] registered taskstats version 1
[ 1.385946] Loading compiled-in X.509 certificates
[ 1.386805] Key type ._fscrypt registered
[ 1.386837] Key type .fscrypt registered
[ 1.386865] Key type fscrypt-provisioning registered
[ 1.398478] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.398828] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.398929] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.405640] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.406734] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.406768] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.437052] of_cfs_init
[ 1.437335] of_cfs_init: OK
[ 1.458400] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.460108] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.461829] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.465082] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.466783] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.473580] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.474789] Waiting for root device PARTUUID=6c586e13-02...
[ 1.507790] random: fast init done
[ 1.533122] mmc1: new high speed SDIO card at address 0001
[ 1.576071] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ 1.576997] mmcblk0: mmc0:aaaa SE32G 29.7 GiB
[ 1.579129] mmcblk0: p1 p2
[ 1.604645] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.604745] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.609690] devtmpfs: mounted
[ 1.618652] Freeing unused kernel memory: 2048K
[ 1.653854] Run /sbin/init as init process
[ 1.653884] with arguments:
[ 1.653899] /sbin/init
[ 1.653914] with environment:
[ 1.653928] HOME=/
[ 1.653942] TERM=linux
[ 1.723545] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.916521] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.916570] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.916604] usb 1-1: Product: USB2.0 Hub
[ 1.918598] hub 1-1:1.0: USB hub found
[ 1.918906] hub 1-1:1.0: 4 ports detected
[ 2.045418] systemd[1]: System time before build time, advancing clock.
[ 2.140447] NET: Registered protocol family 10
[ 2.141822] Segment Routing with IPv6
[ 2.202702] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.203584] systemd[1]: Detected architecture arm.
[ 2.243540] usb 1-1.1: new high-speed USB device number 3 using xhci_hcd
[ 2.250234] systemd[1]: Set hostname to <octopi>.
[ 2.256065] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[ 2.446955] usb 1-1.1: New USB device found, idVendor=05a3, idProduct=9230, bcdDevice= 1.00
[ 2.447018] usb 1-1.1: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 2.447069] usb 1-1.1: Product: USB 2.0 Camera
[ 2.447113] usb 1-1.1: Manufacturer: HD Camera Manufacturer
[ 2.553576] usb 1-1.2: new full-speed USB device number 4 using xhci_hcd
[ 2.690226] usb 1-1.2: New USB device found, idVendor=1eaf, idProduct=0004, bcdDevice= 2.00
[ 2.690276] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.690314] usb 1-1.2: Product: Maple
[ 2.690344] usb 1-1.2: Manufacturer: LeafLabs
[ 2.928023] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.936741] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.937595] systemd[1]: Listening on Journal Socket.
[ 2.938405] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.945990] systemd[1]: Mounting RPC Pipe File System...
[ 2.953456] systemd[1]: Mounting Kernel Debug File System...
[ 2.961216] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.963818] systemd[1]: Created slice User and Session Slice.
[ 2.971183] systemd[1]: Starting Set the console keyboard layout...
[ 3.596508] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.726749] systemd-journald[129]: Received request to flush runtime journal from PID 1
[ 4.252413] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.253288] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.255439] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.255990] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 4.339879] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.363302] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 4.368853] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.370973] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.370998] [vc_sm_connected_init]: start
[ 4.382087] [vc_sm_connected_init]: installed successfully
[ 4.396752] mc: Linux media interface: v0.10
[ 4.438229] videodev: Linux video capture interface: v2.00
[ 4.490466] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.493798] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.495833] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.509903] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 4.510412] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 4.510854] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 4.511172] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 4.511202] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 4.511227] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 4.511250] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 4.511273] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 4.511460] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 4.520267] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.562652] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.582204] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.678256] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.731910] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.767217] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.769258] usbcore: registered new interface driver brcmfmac
[ 4.790139] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[ 4.811441] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
[ 4.815218] usbcore: registered new interface driver cdc_acm
[ 4.815238] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 4.831530] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 4.844181] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (05a3:9230)
[ 4.899862] input: USB 2.0 Camera: HD USB Camera as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/input/input0
[ 4.900303] usbcore: registered new interface driver uvcvideo
[ 4.900319] USB Video Class driver (1.1.1)
[ 4.902353] [drm] No displays found. Consider forcing hotplug if HDMI is attached
[ 4.902475] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 4.902871] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 5.062406] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.079171] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 5.174129] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.174180] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.177564] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.177608] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.181807] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.181866] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 7.085945] random: crng init done
[ 7.085960] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.158695] uart-pl011 fe201000.serial: no DMA platform data
[ 7.282299] 8021q: 802.1Q VLAN Support v1.8
[ 7.577343] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 7.687590] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 7.987070] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 7.987607] bcmgenet fd580000.ethernet eth0: Link is Down
[ 12.153790] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 12.153846] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 13.893274] Bluetooth: Core ver 2.22
[ 13.894185] NET: Registered protocol family 31
[ 13.894203] Bluetooth: HCI device and connection manager initialized
[ 13.894233] Bluetooth: HCI socket layer initialized
[ 13.894257] Bluetooth: L2CAP socket layer initialized
[ 13.894297] Bluetooth: SCO socket layer initialized
[ 13.905007] Bluetooth: HCI UART driver ver 2.3
[ 13.905029] Bluetooth: HCI UART protocol H4 registered
[ 13.905127] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 13.905561] Bluetooth: HCI UART protocol Broadcom registered
[ 14.081634] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.081645] Bluetooth: BNEP filters: protocol multicast
[ 14.081663] Bluetooth: BNEP socket layer initialized
[ 100.975472] usb 1-1.2: USB disconnect, device number 4
[202992.194149] usb 1-1.2: new full-speed USB device number 5 using xhci_hcd
[202992.330687] usb 1-1.2: New USB device found, idVendor=1eaf, idProduct=0004, bcdDevice= 2.00
[202992.330710] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[202992.330729] usb 1-1.2: Product: Maple
[202992.330747] usb 1-1.2: Manufacturer: LeafLabs
[202992.337587] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15
connectivity.connection_check: 9.9.9.9:53
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 3959291904
env.os.bits: 32
env.os.id: linux
env.os.platform: linux2
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.2
env.plugins.pi_support.octopi_version: 0.17.0
env.python.pip: 19.3.1
env.python.version: 2.7.16
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.3
printer.firmware: Marlin 2.0.7.2 (Nov 27 2020
