I tried to change sdcards, flash different versions of octoprint.
Now I'm with 1.3.7rc4. My printer is DIY and firmware is Marlin 1.1.6.
octoprint.log: octoprint.log (98.5 KB)
No. When I flash new image I changed the resolution. It works perfect a few days and then it getting lagging. I tried all USB ports, change camera settings to default but it doesn't work. Only fix that I found is to flash new image but I should install all plugins and set all settings again and again.
Different question what plugin alows you to show your pi's CPU temp? Thats quit cool... + Is the authentication actually "save" I never trusted it enough to forward it through the router
