I'm testing a hardware/software interface to drive enclosure LEDs
If I use a real printer M118 echoes correctly
Using the virtual printer, it just replies ok
Is this expected behaviour?
tried with "real" printer and all works fine
virtual printer - not so much
Logs (octoprint.log, serial.log or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support!) terminal log REAL
Send: M118 //action:LEDs red <= this is my command
Recv: //action:LEDs red <= response
Recv: ok
Send: M118 //action:LEDs green
Recv: //action:LEDs green
Recv: ok
terminal log VIRTUAL
Send: M118 //action:LEDs blue <= this is my command
Recv: ok <= response
Recv: T:21.30 /0.00 B:21.30 /0.00 @:64
Recv: Not SD printing
Recv: wait
Recv: wait
Recv: wait
OctoPrint 1.4.0 OctoPi 0.17.0
printer: Creality Ender-3
OS: Windows 10
browser: Chrome
You may want to hold back until the next release, my understanding is the Virtual printer has been extracted out into it's own full plugin now, so you might want to submit your changes against it.
Only the settings have finally been extracted into the full plugin that was there for a while now, the code location is still the same. Filing a PR against maintenance should find everything still where it's expected.
Yep, and I'm not really interested into changing that tbh... The only thing I could imagine putting there is a JSON or YAML editor to adjust them that way. I only added the toggle in as it makes quick tests on fresh instances so much easier.
If someone was to design a beautiful settings interface for it... would it be considered? Could be hidden behind the checkbox until enabled to not confuse users too much.
If it was somehow populated automatically from the definitions, yes. Otherwise, eh The problem is, I really don't want to have to maintain and translate yet another bunch of settings for a development tool.
It could maybe be done... Will take a look at some point. Have some idea as to how, but it may not be pretty if it is done automatically from the settings.
