I just installed OctoPi on my Raspberry Pi and it worked out fine. Web camera worked without me doing anything extra, really nice setup. However, when I connect my printer - which seems to work fine, it can't do anything.
I've tried running in safe mode to see if the plugins I installed cause any troubles, but it doesn't seem like it. We can also see in the logs that commands are sent and being received, so I'm not sure why the printer doesn't do anything.
Any suggestions on where to start in order to fix this? I'm using the latest version of OctoPrint (I think it was released on July 25th). My printer isn't updated and if I read the logs correct, I have a firmware version from 2016? Something is compiled in 2016 at least.
Ideas or suggestions are welcomed!
Serial port list: ['/dev/ttyUSB0']
Connecting to: /dev/ttyUSB0
Connected to: Serial<id=0x6b383c30, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection...
Trying baudrate: 115200
Recv: start
Send: N0 M110 N0125
Changing monitoring state from "Detecting baudrate" to "Operational"
Recv: echo:Marlin 1.0.0
Recv: echo: Last Updated: Oct 7 2016 08:56:29 | Author: (none, default config)
Recv: Compiled: Oct 7 2016
Send: N0 M110 N0125
Recv: echo: Free Memory: 3892 PlannerBufferBytes: 1232
Recv: echo:Hardcoded Default Settings Loaded
Recv: echo:Steps per unit:
Recv: echo: M92 X81.00 Y81.00 Z400.50 E94.30
Recv: echo:Maximum feedrates (mm/s):
Recv: echo: M203 X450.00 Y450.00 Z5.00 E25.00
Recv: echo:Maximum Acceleration (mm/s2):
Recv: echo: M201 X3000 Y3000 Z100 E3000
Recv: echo:Acceleration: S=acceleration, T=retract acceleration
Recv: echo: M204 S800.00 T800.00
Recv: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
Recv: echo: M205 S0.00 T0.00 B20000 X10.00 Z0.40 E1.00
Recv: echo:Home offset (mm):
Recv: echo: M206 X0.00 Y0.00 Z0.00
Recv: echo:PID settings:
Recv: echo: M301 P33.41 I1.47 D189.27
Recv: echo:SD card ok
Recv: ok
Recv: ok
Send: N1 M11539
Send: N2 M2118
Recv: FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:http://www.mendel-parts.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
Recv: ok
Send: M20
Recv: ok
Recv: Begin file list
Recv: CFDMP_~1.GCO
Recv: echo:Cannot open subdir
Recv: 1/
Recv: /TRASHE~1/501/O~1.GCO
Recv: /TRASHE~1/501/CFDMP_~1.GCO
Recv: /TRASHE~1/501/CFDMP_~2.GCO
Recv: /TRASHE~1/501/CFDMP_~3.GCO
Recv: /TRASHE~1/501/CFDMP_~4.GCO
Recv: /TRASHE~1/501/PIXEL_~1.GCO
Recv: /TRASHE~1/501/CFDMP_~5.GCO
Recv: /TRASHE~1/501/CFDMP~82.GCO
Recv: /TRASHE~1/501/CFDMP~85.GCO
Recv: /TRASHE~1/501/CFDMP~88.GCO
Recv: /TRASHE~1/501/CFDMP~91.GCO
Recv: /TRASHE~1/501/CFDMP~94.GCO
Recv: /TRASHE~1/501/CFDMP~97.GCO
Recv: /TRASHE~1/501/CFDM~103.GCO
Recv: /TRASHE~1/501/CFDM~106.GCO
Recv: End file list
Recv: ok
Send: M105
Recv: ok T:26.7 /0.0 B:26.4 /0.0 T0:26.7 /0.0 @:0 B@:0
Send: G91
Recv: ok
Send: G1 Y-10 F6000
Send: G90
Recv: ok
Recv: ok
Send: M105
Recv: ok T:26.7 /0.0 B:27.2 /0.0 T0:26.7 /0.0 @:0 B@:0
Send: M105
Recv: ok T:26.8 /0.0 B:26.7 /0.0 T0:26.8 /0.0 @:0 B@:0
Send: G91
Send: G1 Y-10 F6000
Recv: ok
Send: G90
Recv: ok
Recv: ok
Send: M105
Recv: ok T:26.7 /0.0 B:26.6 /0.0 T0:26.7 /0.0 @:0 B@:0
Send: G91
Recv: ok
Send: G1 X10 F6000
Send: G90
Recv: ok
Recv: ok
Send: G91
Send: G1 X-10 F6000
Recv: ok
Send: G90
Recv: ok
Recv: ok
Send: G91
Send: G1 X10 F6000
Recv: ok
Send: G90
Recv: ok
Recv: ok
