I get this error when I try to use ssh pi@octopi.local
My first Octoprint went off without a hitch. My 2nd attempt not so much.
I believe my computer remembers my first Pi and won't let me connect to my 2nd one because it thinks it has changed,
How do I dismiss the error?
Thanks Norm
P.S. I have no experience with code of any kind. Just a YouTube follower.
Are both RPi systems still in service? If so, then one of them needs a hostname change. If not, then the warning is just telling you what you already know, this is a new RPi with the "old" hostname. You should be given the option to accept the new identification.
I changed the first pi host name to Ender3 because that is what it is supporting. I want to change the host name of the 2nd one to SV01 because that is what i want to use it on.
The only way i know (You Tube) to change the host name is to connect to it with A SSH command and go into the config utility.
OK thanks. I poked around until i found the offending file opened it with note++ and deleted the only line of text in the file. After that it worked. Thanks everyone for your help.
