I setup OctoPrint via OctoPI today. After a print I shutdown the RPI 3B and installed the camera, everything working fine and camera was found in OctoPrint. After being off for a while I tried installing a touch screen to the RPI, booting it up and running the instructions on GitHub - goodtft/LCD-show: 2.4" 2.8"3.2" 3.5" 5.0" 7.0" TFT LCD driver for the Raspberry PI 3B+/A/A+/B/B+/PI2/ PI3/ZERO/ZERO W with the script being LCD-show/LCD35-show at 1bba9d97a4e779237f3144d035c409ed3a3b2f45 · goodtft/LCD-show · GitHub. I suspect this altered something, but am not Linux savvy enough to know if that was the problem.
Camera model Raspberry PI cam 1.3
What is the problem? Webcam not recognised by OctoPrint
What did you already try to solve it? Reboot
webcams.log when it worked:
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
raspi
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-strea$
<13>Jul 30 16:47:48 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i$
i: Frames Per Second.: 10
i: Format............: JPEG
UVCIOC_CTRL_MAP - Error at Disable video processing: Inappropriate ioctl for devic$
o: HTTP Listen Address..: 127.0.0.1
Goodbye...
webcams.log now:
camera: auto
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/root/bin/webcamd: line 184: printf: 0x: invalid hex number
<13>Jul 30 19:21:20 root: Starting USB webcam
i: Using V4L2 device.: /dev/video10
Error opening device /dev/video10: video capture not supported.
i: init_VideoIn failed
Goodbye...
**Additional information about your setup** (OctoPrint version, OctoPi version, ...)
