What is the problem? I have 2 OctoPrints installed on 2 separate Raspberry Pi's, One a 3A+ and the other a 4B+. Running a Mid 2011 27" iMac running MacOS High Sierra 10.13.6 with 32GB RAM and Safari 13.1.2. Browser and OS are updated as far as they can be.
What did you already try to solve it? Restarted Mac, Restarted Browsers.
Logs (syslog, dmesg, ... no logs, no support) - Not sure what logs I can provide here
Router is a Netgear RAX15 with the Pis and the computer connected wirelessly
Ok, My Prusa MK3S is controlled by an Octoprint instance running on a Raspberry Pi 3A+ and is using ~ 400MB of RAM in its window. The Prusa Mini is being controlled by an Octoprint instance running on a Raspberry Pi 4B+ but has a memory footprint of over 1.3GB in its window.
Both Pi's are running the latest release, and are configured the same in terms of plugins.
Anything to look at to reduce the memory footprint?
