ID 046d:092f Logitech, Inc. QuickCam Express Plus
can't capture image
change Config to
- "-r 640x480 -f 10 -y"
- -r 640x480 -f 10 "
- "-r VGA -f 10 -y"
- -r VGA -f 10 "
Nov 15 13:50:00 octopi webcamd[293]: cfg_file: /boot/octopi.txt
Nov 15 13:50:00 octopi webcamd[293]: camera: auto
Nov 15 13:50:00 octopi webcamd[293]: usb options: -r VGA -f 10 -y
Nov 15 13:50:00 octopi webcamd[293]: raspi options: -fps 10
Nov 15 13:50:00 octopi webcamd[293]: http options: -w ./www-octopi -n
Nov 15 13:50:00 octopi webcamd[293]: Explicitly USB device:
Nov 15 13:50:00 octopi webcamd[293]: -----------------------------------------------
Nov 15 13:50:00 octopi webcamd[293]: Found video devices:
Nov 15 13:50:00 octopi webcamd[293]: /dev/video0
Nov 15 13:50:00 octopi webcamd[293]: /dev/video10
Nov 15 13:50:00 octopi webcamd[293]: /dev/video11
Nov 15 13:50:00 octopi webcamd[293]: /dev/video12
Nov 15 13:50:00 octopi webcamd[293]: config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
Nov 15 13:50:00 octopi root[396]: Starting USB webcam
Nov 15 13:50:00 octopi webcamd[293]: <13>Nov 15 13:50:00 root: Starting USB webcam
Nov 15 13:50:00 octopi webcamd[293]: Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i input_uvc.so -r VGA -f 10 -y -d /dev/video0
Nov 15 13:50:00 octopi mjpg_streamer[397]: MJPG-streamer [397]: starting application
Nov 15 13:50:00 octopi webcamd[293]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
Nov 15 13:50:00 octopi mjpg_streamer[397]: MJPG-streamer [397]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
Nov 15 13:50:01 octopi webcamd[293]: i: Using V4L2 device.: /dev/video0
Nov 15 13:50:01 octopi webcamd[293]: i: Desired Resolution: 640 x 480
Nov 15 13:50:01 octopi webcamd[293]: i: Frames Per Second.: 10
Nov 15 13:50:01 octopi webcamd[293]: i: Format............: YUYV
Nov 15 13:50:01 octopi webcamd[293]: i: JPEG Quality......: 80
Nov 15 13:50:01 octopi webcamd[293]: i: TV-Norm...........: DEFAULT
Nov 15 13:50:01 octopi mjpg_streamer[397]: MJPG-streamer [397]: Using V4L2 device.: /dev/video0
Nov 15 13:50:01 octopi mjpg_streamer[397]: MJPG-streamer [397]: Desired Resolution: 640 x 480
Nov 15 13:50:01 octopi mjpg_streamer[397]: MJPG-streamer [397]: Frames Per Second.: 10
Nov 15 13:50:01 octopi mjpg_streamer[397]: MJPG-streamer [397]: Format............: YUYV
Nov 15 13:50:01 octopi mjpg_streamer[397]: MJPG-streamer [397]: JPEG Quality......: 80
Nov 15 13:50:01 octopi mjpg_streamer[397]: MJPG-streamer [397]: TV-Norm...........: DEFAULT
Nov 15 13:50:01 octopi webcamd[293]: i: The specified resolution is unavailable, using: width 352 height 288 instead
Nov 15 13:50:01 octopi webcamd[293]: i: Could not obtain the requested pixelformat: YUYV , driver gave us: RGB3
Nov 15 13:50:01 octopi webcamd[293]: ... will try to handle this by checking against supported formats.
Nov 15 13:50:01 octopi webcamd[293]: Init v4L2 failed !! exit fatal
Nov 15 13:50:01 octopi webcamd[293]: i: init_VideoIn failed
Nov 15 13:50:01 octopi mjpg_streamer[397]: MJPG-streamer [397]: init_VideoIn failed
Nov 15 13:50:01 octopi webcamd[293]: Done bring up all configured video device
Nov 15 13:50:01 octopi webcamd[293]: Goodbye...
Nov 15 13:50:01 octopi systemd[1]: webcamd.service: Succeeded.
Nov 15 13:50:01 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
Nov 15 13:50:02 octopi systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling restart.
Nov 15 13:50:02 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 1.
Nov 15 13:50:02 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Nov 15 13:50:02 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Nov 15 13:50:02 octopi webcamd[429]: Starting up webcamDaemon...
