logitech C525 connected to a usb-hub to a "pi zero w2" on a 2A psu
pi@octopi:~ $ lsusb
Bus 001 Device 004: ID 046d:0826 Logitech, Inc. HD Webcam C525
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
binding adress already in use, and i think that is the reason why webcam keeps forever loading on "octopi.local"...
The second issue is that it cannot decide wether it wants to be at "/dev/video0" or "/dev/video1" so it wont always find it as it is on 1 but still keeps looking for video0?
had struggels to get the C525 detected, aparently i have one dead port on the hub but in those struggels i did somethings... i do not quite recall exactly and there should be an easier solution than re installing octo print, if not only for gaining more knowledge of linux. but i think i got a second mjpg server running from what i have googled.
pi@octopi:~ $ ps -ax|grep mjpg
416 ? Sl 0:00 ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -d dev/video1 -r 1280x720 -f 30 -d /dev/video0
1377 pts/0 S+ 0:00 grep --color=auto mjpg
the problem being that the second one now pid 1377 will keep increasing with 1 every second, and killing it with "sudo kill -9 pid" only bring it back 1 second later, but ive not been able to locate any install package of it due to either other name than mjpg or my own incompetence while the latter is more likely
for the video0/1 struggle someone sugested adding the -d:
sudo nano boot/octopi.txt
camera="usb"
camera_usb_options="-d dev/video1 -r 1280x720 -f 30"
besides those 2 lines nothing has been enabled, which should be fine?
pi@octopi:/ $ root/bin/webcamd
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: usb
usb options: -d dev/video1 -r 1280x720 -f 30
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video2
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video1
<13>Feb 1 13:27:19 pi: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -d dev/video1 -r 1280x720 -f 30 -d /dev/video1
i: Using V4L2 device.: /dev/video1
i: Desired Resolution: 1280 x 720
i: Frames Per Second.: 30
i: Format............: JPEG
Goodbye...
pi@octopi:/ $ UVCIOC_CTRL_ADD - Error at Pan (relative): Inappropriate ioctl for device (25)
o: HTTP Listen Address..: 127.0.0.1
bind: Address already in use
o: server_thread(): bind(8080) failed
octoprint version: Version 1.7.3
octopi: Version 0.18.0, running on Raspberry Pi Zero 2 Rev 1.0
