Logitech C920
When I set the camera to 1920x1080 30fps (a setting the camera is built to do) it causes the tab in Firefox that is running the Octoprint interface to lag out significantly and become almost non responsive. Ex. clicking a different tab will take 15-20 seconds to respond.
Changed it down to 1280x720 20fps now it works great! While this is fine for most uses, some of my projects require an HD timelapse as part of the delivery.
no webcamd.log existed when I went to look for it with the settings applied.
Latest Octopi & Octoprint. Raspberry Pi 4 4GB (heatsinks and active cooling)
