Camera model Amcrest AWC201-B
From a cold start when i power up the printer and raspberry pi the camera will in 1 out of 2 times not connect, on octoprint it just says webcam stream loading and the LED lights on the camera will not light up.
The camera lights will be on just until the point of where the octodash screen for the rasbperry pi will load up.
If i turn all off, wait and turn it back on, sometimes after a few times the camera will work. If the camera is working it stays working. If i leave it powered on it is fine, this issue happens after all has been turned off and it powered back on.
I have tried a powered USB hub which the camera uses seperatley. It has a 1 amp power supply exclusively for the camera. Would like to be able to understand if there is an error log somewhere telling me why the camera shuts down during the boot up process.
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Jan 24 22:13:08 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
i: Frames Per Second.: 10
i: Format............: JPEG
o: HTTP Listen Address..: 127.0.0.1
Goodbye...
i: select() timeout
i: cleaning up resources allocated by input thread
camera: auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Jan 24 22:30:25 root: Starting USB webcam
Goodbye...
Octoprint Version 1.7.2
Raspberry PI 4, 4gb with touch screen running octo dash. Running through the officail raspberry pi power supply.
Webcam uses a powered usb hub
Also have octopod app on phone.
