A cheap one I found on amazon made by "iMXPW" link if needed
I set it up to run on startup, same as the octoprint service, only problem is OP runs fine, by the streamer service doesn't
Tried completely deleting everything in mjpg-streamer, then reinstalling it, no change.
Not sure if I did something wrong, I don't see webcamd.log in the directory. But here's webcam file (can't insert it so here's a drive link) webcamdaemon and rc.local
I'm using ubuntu on an HP desktop, manual setup so I didn't use OctoPi, but my Ubuntu version is 20.04.3
Looks like the username is wrong in the webcam file, /home/p/... -> /home/pi/...:
#!/bin/bash
# Start / stop streamer daemon
case "$1" in
start)
/home/p/scripts/webcamDaemon >/dev/null 2>&1 &
echo "$0: started"
stop)
pkill -x webcamDaemon
pkill -x mjpg_streamer
echo "$0: stopped"
echo "Usage: $0 {start|stop}" >&2
esac
Ok, update, I think everything is good, but in /etc/hostname, the guide put octolinux, but not sure if it's device specific. What do I put? (below is what's in /etc/hostname
127.0.0.1 localhost.localdomain localhost
::1 localhost6.localdomain6 localhost6
The following lines are desirable for IPv6 capable hosts
::1 localhost ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
127.0.1.1 octolinux
The hostname is up to you - it's how your device will identify itself to the network. It can be whatever you want.
