The webcam fails after a while, and only restarting the PI seems to fix the issue. Except that lately it seems to like to fail after a print has started, and right when I need to leave the room. Obviously can't restart the Pi then. I did a fair amount of debug (detailed below). It appears it's conflicting with OctoPrint. How can that be?
I've done some digging and here's what I know:
- Accessing it directly via http://octopi.local:8080/webcam/?action=stream only shows a 404
- The logs (via
journalctl -u webcamd) are shown below. Basically I'm just seeing that the camera starts (I see the physical light also come on), but the page does not change, and the log seems to indicate a port conflict on 8080 - I did a
sudo netstat -lptn(results also below), found the offending process id, and ran ps. It appears that OctoPrint has something also running on 8080...
Logs
journalctl
Jan 09 11:31:30 octopi webcamd[6713]: config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device:
Jan 09 11:31:30 octopi root[6736]: Starting USB webcam
Jan 09 11:31:30 octopi webcamd[6713]: <13>Jan 9 11:31:30 root: Starting USB webcam
Jan 09 11:31:30 octopi webcamd[6713]: Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i input_uvc.so -r 1920x1080 -f 15 -d /dev/video1
Jan 09 11:31:30 octopi mjpg_streamer[6737]: MJPG-streamer [6737]: starting application
Jan 09 11:31:30 octopi mjpg_streamer[6737]: MJPG-streamer [6737]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
Jan 09 11:31:30 octopi webcamd[6713]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
Jan 09 11:31:30 octopi webcamd[6713]: i: Using V4L2 device.: /dev/video1
Jan 09 11:31:30 octopi webcamd[6713]: i: Desired Resolution: 1920 x 1080
Jan 09 11:31:30 octopi webcamd[6713]: i: Frames Per Second.: 15
Jan 09 11:31:30 octopi webcamd[6713]: i: Format............: JPEG
Jan 09 11:31:30 octopi webcamd[6713]: i: TV-Norm...........: DEFAULT
Jan 09 11:31:30 octopi mjpg_streamer[6737]: MJPG-streamer [6737]: Using V4L2 device.: /dev/video1
Jan 09 11:31:30 octopi mjpg_streamer[6737]: MJPG-streamer [6737]: Desired Resolution: 1920 x 1080
Jan 09 11:31:30 octopi mjpg_streamer[6737]: MJPG-streamer [6737]: Frames Per Second.: 15
Jan 09 11:31:30 octopi mjpg_streamer[6737]: MJPG-streamer [6737]: Format............: JPEG
Jan 09 11:31:30 octopi mjpg_streamer[6737]: MJPG-streamer [6737]: TV-Norm...........: DEFAULT
Jan 09 11:31:30 octopi webcamd[6713]: UVCIOC_CTRL_ADD - Error at Pan (relative): Inappropriate ioctl for device (25)
Jan 09 11:31:30 octopi webcamd[6713]: UVCIOC_CTRL_ADD - Error at Tilt (relative): Inappropriate ioctl for device (25)
Jan 09 11:31:30 octopi webcamd[6713]: UVCIOC_CTRL_ADD - Error at Pan Reset: Inappropriate ioctl for device (25)
Jan 09 11:31:30 octopi webcamd[6713]: UVCIOC_CTRL_ADD - Error at Tilt Reset: Inappropriate ioctl for device (25)
Jan 09 11:31:30 octopi webcamd[6713]: UVCIOC_CTRL_ADD - Error at Pan/tilt Reset: Inappropriate ioctl for device (25)
Jan 09 11:31:30 octopi webcamd[6713]: UVCIOC_CTRL_ADD - Error at Focus (absolute): Inappropriate ioctl for device (25)
Jan 09 11:31:30 octopi webcamd[6713]: UVCIOC_CTRL_MAP - Error at Pan (relative): Inappropriate ioctl for device (25)
Jan 09 11:31:30 octopi webcamd[6713]: UVCIOC_CTRL_MAP - Error at Tilt (relative): Inappropriate ioctl for device (25)
Jan 09 11:31:30 octopi webcamd[6713]: UVCIOC_CTRL_MAP - Error at Pan Reset: Inappropriate ioctl for device (25)
Jan 09 11:31:30 octopi webcamd[6713]: UVCIOC_CTRL_MAP - Error at Tilt Reset: Inappropriate ioctl for device (25)
Jan 09 11:31:30 octopi webcamd[6713]: UVCIOC_CTRL_MAP - Error at Pan/tilt Reset: Inappropriate ioctl for device (25)
Jan 09 11:31:30 octopi webcamd[6713]: UVCIOC_CTRL_MAP - Error at Focus (absolute): Inappropriate ioctl for device (25)
Jan 09 11:31:30 octopi webcamd[6713]: UVCIOC_CTRL_MAP - Error at LED1 Mode: Inappropriate ioctl for device (25)
Jan 09 11:31:30 octopi webcamd[6713]: UVCIOC_CTRL_MAP - Error at LED1 Frequency: Inappropriate ioctl for device (25)
Jan 09 11:31:30 octopi webcamd[6713]: UVCIOC_CTRL_MAP - Error at Disable video processing: Inappropriate ioctl for device (25)
Jan 09 11:31:30 octopi webcamd[6713]: UVCIOC_CTRL_MAP - Error at Raw bits per pixel: Inappropriate ioctl for device (25)
Jan 09 11:31:30 octopi webcamd[6713]: o: www-folder-path......: ./www-octopi/
Jan 09 11:31:30 octopi webcamd[6713]: o: HTTP TCP port........: 8080
Jan 09 11:31:30 octopi webcamd[6713]: o: HTTP Listen Address..: (null)
Jan 09 11:31:30 octopi webcamd[6713]: o: username:password....: disabled
Jan 09 11:31:30 octopi webcamd[6713]: o: commands.............: disabled
Jan 09 11:31:30 octopi mjpg_streamer[6737]: MJPG-streamer [6737]: www-folder-path......: ./www-octopi/
Jan 09 11:31:30 octopi webcamd[6713]: bind: Address already in use
Jan 09 11:31:30 octopi mjpg_streamer[6737]: MJPG-streamer [6737]: HTTP TCP port........: 8080
Jan 09 11:31:30 octopi mjpg_streamer[6737]: MJPG-streamer [6737]: HTTP Listen Address..: (null)
Jan 09 11:31:30 octopi mjpg_streamer[6737]: MJPG-streamer [6737]: username:password....: disabled
Jan 09 11:31:30 octopi mjpg_streamer[6737]: MJPG-streamer [6737]: commands.............: disabled
Jan 09 11:31:30 octopi mjpg_streamer[6737]: MJPG-streamer [6737]: starting input plugin input_uvc.so
Jan 09 11:31:30 octopi mjpg_streamer[6737]: MJPG-streamer [6737]: starting output plugin: output_http.so (ID: 00)
Jan 09 11:31:31 octopi webcamd[6713]: Done bring up all configured video device
Jan 09 11:31:31 octopi webcamd[6713]: Goodbye...
netstat
tcp 0 0 127.0.0.1:5000 0.0.0.0:* LISTEN 442/python2
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 442/python2
ps
PID TTY STAT TIME COMMAND
442 ? Sl 47:20 /home/pi/oprint/bin/python2 /home/pi/oprint/bin/octoprint serve --host=127.0.0.1 --port=5000
OctoPrint version:
OctoPi version:
Camera: Logitech 920
Plugins:
Action Command Prompt Support
Announcement Plugin
Anonymous Usage Tracking
Application Keys Plugin
Autoscroll (0.0.2)
Backup & Restore
Bed Visualizer (0.1.11)
Core Wizard
Discovery
EEPROM Marlin Editor Plugin (1.2.1)
Error Tracking
Exclude Region (0.2.0)
Floating Navbar (0.3.1)
Force Login
Fullscreen Plugin (0.0.4)
GcodeEditor (0.2.7)
Logging
Navbar Temperature Plugin (0.11)
OctoFlat Theme (0.2.0)
Octolapse (0.3.4)
Pi Support Plugin
Plugin Manager
Printer Safety Check
PrintTimeGenius Plugin (2.2)
Sidebar Webcam (0.1.7)
Simple Emergency Stop (0.2.5)
Slicer (1.4.3)
SlicerSettingsParser (2.0.1)
SlicerSettingsTab (1.0.3)
Software Update
Tab Order (0.5.5)
The Spaghetti Detective (1.0.8)
Themeify (1.2.0)
TouchUI (0.3.13)
Virtual Printer
Webcam Tab (0.1.2)
