Webcam inconsistent behavior
I am running the latest octoprint version. I am also a newbie to this.
Logitech c110
Sometimes it works and sometimes it wont
Tried command vcgencmd get_camera with the following output supported=1 detected=0
Tried lsusb with the follwoing result Bus 001 Device 004: ID 046d:0829 Logitech, Inc.
Tried systemctl status webcamd
● webcamd.service - the OctoPi webcam daemon with the user specified config
   Loaded: loaded (/etc/systemd/system/webcamd.service; enabled; vendor preset:
   Active: active (running) since Tue 2021-05-04 12:37:04 BST; 8min ago
  Process: 822 ExecStart=/root/bin/webcamd (code=exited, status=0/SUCCESS)
 Main PID: 849 (mjpg_streamer)
    Tasks: 18 (limit: 1938)
           └─849 ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 1
May 04 12:37:03 octopi mjpg_streamer[849]: MJPG-streamer [849]: www-folder-path.
May 04 12:37:03 octopi mjpg_streamer[849]: MJPG-streamer [849]: HTTP TCP port...
May 04 12:37:03 octopi mjpg_streamer[849]: MJPG-streamer [849]: HTTP Listen Addr
May 04 12:37:03 octopi mjpg_streamer[849]: MJPG-streamer [849]: username:passwor
May 04 12:37:03 octopi mjpg_streamer[849]: MJPG-streamer [849]: commands........
May 04 12:37:03 octopi mjpg_streamer[849]: MJPG-streamer [849]: starting input p
May 04 12:37:03 octopi mjpg_streamer[849]: MJPG-streamer [849]: starting output
May 04 12:37:04 octopi systemd[1]: Started the OctoPi webcam daemon with the use
May 04 12:37:08 octopi mjpg_streamer[849]: MJPG-streamer [849]: select() timeout
May 04 12:37:08 octopi mjpg_streamer[849]: MJPG-streamer [849]: cleaning up reso
lines 1-19/19 (END)
If you want anymore details do please ask.
