Webcam inside Docker container
Docker Compose:
version: '3'
services:
  octoprint:
    container_name: octoprint
    image: octoprint/octoprint
    restart: unless-stopped
    ports:
      - 6790:80
    devices:
     - /dev/video0:/dev/video0
    volumes:
     - /mnt/docker/octoprint:/octoprint
    environment:
     - ENABLE_MJPG_STREAMER=true
https://www.amazon.com/gp/product/B088NNQMVQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Can't get the mjpg streamer to start showing any video from my camera
Tried a third party mjpg streamer but it threw an error that the device wasn't there, but I am able to see it in CLI:
sudo v4l2-ctl --device=/dev/video0 --all
[sudo] password for b:
Driver Info (not using libv4l2):
        Driver name   : uvcvideo
        Card type     : USB Color Camera: USB Color Cam
        Bus info      : usb-0000:02:01.0-1
        Driver version: 4.15.18
        Capabilities  : 0x84200001
                Video Capture
                Streaming
                Extended Pix Format
                Device Capabilities
        Device Caps   : 0x04200001
                Video Capture
                Streaming
                Extended Pix Format
Priority: 2
Video input : 0 (Camera 1: ok)
Format Video Capture:
        Width/Height      : 640/480
        Pixel Format      : 'MJPG'
        Field             : None
        Bytes per Line    : 0
        Size Image        : 614989
        Colorspace        : Default
        Transfer Function : Default (maps to Rec. 709)
        YCbCr/HSV Encoding: Default (maps to ITU-R 601)
        Quantization      : Default (maps to Full Range)
        Flags             :
Crop Capability Video Capture:
        Bounds      : Left 0, Top 0, Width 640, Height 480
        Default     : Left 0, Top 0, Width 640, Height 480
        Pixel Aspect: 1/1
Selection: crop_default, Left 0, Top 0, Width 640, Height 480
Selection: crop_bounds, Left 0, Top 0, Width 640, Height 480
Streaming Parameters Video Capture:
        Capabilities     : timeperframe
        Frames per second: 30.000 (30/1)
        Read buffers     : 0
                     brightness 0x00980900 (int)    : min=-64 max=64 step=1 default=0 value=0
                       contrast 0x00980901 (int)    : min=0 max=64 step=1 default=32 value=32
                     saturation 0x00980902 (int)    : min=0 max=128 step=1 default=64 value=64
                            hue 0x00980903 (int)    : min=-40 max=40 step=1 default=0 value=0
 white_balance_temperature_auto 0x0098090c (bool)   : default=1 value=1
                          gamma 0x00980910 (int)    : min=72 max=500 step=1 default=100 value=100
                           gain 0x00980913 (int)    : min=0 max=100 step=1 default=0 value=0
           power_line_frequency 0x00980918 (menu)   : min=0 max=2 default=1 value=1
      white_balance_temperature 0x0098091a (int)    : min=2800 max=6500 step=1 default=4600 value=4600 flags=inactive
                      sharpness 0x0098091b (int)    : min=0 max=6 step=1 default=1 value=1
         backlight_compensation 0x0098091c (int)    : min=0 max=2 step=1 default=1 value=1
                  exposure_auto 0x009a0901 (menu)   : min=0 max=3 default=3 value=3
              exposure_absolute 0x009a0902 (int)    : min=1 max=5000 step=1 default=157 value=157 flags=inactive
         exposure_auto_priority 0x009a0903 (bool)   : default=0 value=1
URL
This didn't seem to be intuitive from the compose file, but I put
http://10.168.3.59:6790/webcam/?action=stream
b@fh-ast-docker-01:/mnt$ dmesg | grep USB
[601253.134942] uhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 1
[601253.138808] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[601253.138816] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[601253.154194] hub 1-0:1.0: USB hub found
[601253.176171] ehci-pci 0000:02:01.0: new USB bus registered, assigned bus number 2
[601253.193188] ehci-pci 0000:02:01.0: USB 2.0 started, EHCI 1.00
[601253.194229] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[601253.194233] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[601253.196939] hub 2-0:1.0: USB hub found
[601253.849019] usb 1-1: new full-speed USB device number 2 using uhci_hcd
[601253.921065] usb 2-1: new high-speed USB device number 2 using ehci-pci
[601254.415873] usb 1-1: New USB device found, idVendor=0e0f, idProduct=0003
[601254.415878] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[601254.415880] usb 1-1: Product: VMware Virtual USB Mouse
[601254.552881] usb 1-2: new full-speed USB device number 3 using uhci_hcd
[601254.571100] usb 2-1: New USB device found, idVendor=0c45, idProduct=6366
[601254.571104] usb 2-1: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[601254.571106] usb 2-1: Product: USB Color Camera
[601254.571107] usb 2-1: Manufacturer: USB Color Camera
[601254.571109] usb 2-1: SerialNumber: USB Color Camera
[601254.960483] usb 1-2: New USB device found, idVendor=0e0f, idProduct=0002
[601254.960488] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[601254.960491] usb 1-2: Product: VMware Virtual USB Hub
[601254.971098] hub 1-2:1.0: USB hub found
[601274.859357] uvcvideo: Found UVC 1.00 device USB Color Camera (0c45:6366)
[601274.870619] usbhid: USB HID core driver
[601274.881774] input: USB Color Camera: USB Color Cam as /devices/pci0000:00/0000:00:11.0/0000:02:01.0/usb2/2-1/2-1:1.0/input/input5
[601274.882415] USB Video Class driver (1.1.1)
[601275.002660] input: VMware VMware Virtual USB Mouse as /devices/pci0000:00/0000:00:11.0/0000:02:00.0/usb1/1-1/1-1:1.0/0003:0E0F:0003.0001/input/input6
[601275.062527] hid-generic 0003:0E0F:0003.0001: input,hidraw0: USB HID v1.10 Mouse [VMware VMware Virtual USB Mouse] on usb-0000:02:00.0-1/input0
what do you get from ls -la /dev/video* (with the camera plugged in)?
I have the same issue. Did you manage to get this solved?
I get this when I run ls -la /dev/video*
I use a raspberry pi camera connected with a flex cabel.
