PI camera nightvision OV5647 IR-Cut
Octoprint can detect the camera but i can't get stream, only a sigle frame.
Restarting, reboot, safe mode.
Here is my log:
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Dec 2 08:56:30 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
i: Frames Per Second.: 10
i: Format............: JPEG
o: HTTP Listen Address..: 127.0.0.1
Goodbye...
Octoprint 1.7.3, Octopi 0.18, python 3.7.3.
