Webcam is not streaming
OV5647
No image, no video. Sometimes it works for a while, then for unknown reasons, stops (I realise that just before a print)
I got this error message for the first time while printing today:
HTTPConnectionPool(host='192.168.0.20', port=8080): Max retries exceeded with url: / (Caused by NewConnectionError(': Failed to establish a new connection: [Errno 111] Connection refused'))
In the main octoprint setting page:
Path to FFMPEG is shown
/usr/bin/ffmpeg
Testing says The path is valid
Snapshot stream link says refused to connect
In classic webcam settings
Stream URL /webcam/?action=stream
and Snapshot URL at my device and port 8080 does not work
Tried everything I could find online. Tried to reinstal image from when it was working but it doesnt work anymore. Seems that just removing the storage when powered down might trigger something, I dont know.
IC2 is enabled., Tried on off, same with legacy webcam in raspi-config.
I can actualy see that the cam is available and accessible:
libcamera-hello --list-cameras
Available cameras
0 : ov5647 [2592x1944] (/base/soc/i2c0mux/i2c@1/ov5647@36)
Modes: 'SGBRG10_CSI2P' : 640x480 [58.92 fps - (16, 0)/2560x1920 crop]
1296x972 [43.25 fps - (0, 0)/2592x1944 crop]
1920x1080 [30.62 fps - (348, 434)/1928x1080 crop]
2592x1944 [15.63 fps - (0, 0)/2592x1944 crop]
yes
no
Log
https://paste.octoprint.org/OOMieexPUE
Running PiHole and HomeAssistant on different docker containers
Octoprint and these work fine otherwise
OctoPod is configured, was working well with cam. Now, no cam, getting Error response HTTP : 503 for the link to the webcam streaming
I would appreciate help, I'm a beginner and searched a lot online to find a fix but cant seem to find anything. Thanks!
Hello @JPc !
Can you please attach the systeminfo bundle to you r next post.
Good morning,
I have the same problem, for a few days my picam no longer sends video.
I can't find the solution.
Here is my systeminfobundle.
Thanks for your help.
octoprint-systeminfo-20230815111005.zip (30.1 KB)
Hi, here it is:
octoprint-systeminfo-20230816151953.zip (41.9 KB)
After many tests with backups I had made, I narrowed it down to the IP address configuration.
octopi.local:5001 no camera is going through
Pi address 192.168.0.XX with no ports added enables the camera to go through
I don't know how the configuration was changed in my installation but it seems to be the only difference. And now it works. Hope this helps someone else
Edit: It might be a conflict with home assistant. Everything was good and -litterally overnight - after a clean install of home assistant (portainer), i can't access with octopi directly with no ports added, and camera is not streaming anymore, and same error message.
