Hello, everybody!
After switching from OctoPi on a RaspberryPi to Octoprint/CasaOS on an x86 my webcam did not work anymore in the new environment. My main question is: Are there different Camera models supported in these different environments?
Thank you,
Marcus
With lsusb it lists as "Guillemot Corp. Deluxe Optical Glass"
When I was running OctoPi on a Raspberry Pi 4, the Cam worked perfectly fine. After switching to Octoprint, running in a CasaOS container, the same cam does'nt work anymore. Everything else is fine, I can communicate with OctoPrint, send files, print, control the printer via the UI, everything except the camera.
I checked, if webcam support is activated (it is)
I checked the cam (still works on other systems)
I checked the path to ffmpeg (which is valid)
I checked both modes "default webcam" and "classic webcam" (no pic, but different aspect ratios)
I tried all USB ports on the device (the cam shows up in the list with lsusb, on every port)
Yes, doesn't make any difference.
Hardware
ThinClient Dell Wyse 5010 / 4 GB Ram / 256 GB SSD
Printer: Artillery Sidewinder X1, Marlin 2.0.9.2
Webcam: Guillemot Corp. Deluxe Optical Glass
Software
Debian 12
CasaOS 0.4.15
OctoPrint version 1.10.3
octoprint-systeminfo-20250122115022.zip (18.0 KB)
