I have been having issues with a couple of different cheap webcams I got from Amazon. When the browser control tab is left open for a period of time (time varies - for one cam it can be hours or minutes but for the newer cam I just got, it can be hours/days) the camera feed will go black, and if I switch tabs or switch to a different tab entirely I will get an "Aw Snap" error in Chrome. There was a similar thread posted a few years ago, but I thought it might be better to start a new one. I have NOT seen this issue using an older Logitech C920 camera, but I prefer to use that one for my PC for web conferencing because the quality is better and it isn't a super-wide angle view like the Aukey cam I have tried.
These are the cams I have tried:
Aukey PC-LM1E:
https://www.amazon.com/gp/product/B072MMH33F/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Brand unknown (Greatlizard?):
https://www.amazon.com/gp/product/B08HH7LVB5/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
The second camera above is my most recent order and is the one that seems to last longer before the error occurrs. It is identified as product-vendor 23c5:1478. I don't know the ID of the Aukey cam as it isn't plugged in right now.
I have tried using the broken fps fix for the newer "greatlizard" camera without success.
NO
Complete Logs
I am waiting for one of the errors to occur again and will post logs, but for now, here is the webcamd.log content with the greatlizard cam:
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 1920x1080 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-st$
<13>Feb 24 13:21:13 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1$
i: Desired Resolution: 1920 x 1080
i: Frames Per Second.: 10
i: Format............: JPEG
i: FPS coerced ......: from 10 to 30
UVCIOC_CTRL_MAP - Error at Disable video processing: Inappropriate ioctl for de$
UVCIOC_CTRL_MAP - Error at Raw bits per pixel: Inappropriate ioctl for device ($
o: HTTP Listen Address..: 127.0.0.1
Goodbye...
