KEYESTUDIO
Can't get the camera to work after fresh install of octoPi using the raspberry pi imager.
Did you already try to solve it?
Yes it's been about 2 weeks still can't get it to work.
Logs (/var/log/webcamd.log
, syslog, dmesg, ... no logs, no support)
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
Raspberry Pi 4 Model B 8 GB
OctoPrint 1.8.6
**Update
On a fresh install of Rpi, what streaming software have you installed mjpg-streamer, inlab-mjpg-streamer ??
With the OctoPi image, it would be mjpg-streamer
through the webcamd scripts.
The problem is still ongoing switched to a USB cam for the time being and that works flawlessly. But I would like to get my Logitech webcam back and use the pi cam. Any and all help is welcome, and yes mjpeg-streamer is installed thank you for the suggestion.
Same here. Upgraded my raspi and octopi, now Logitech C270 "stopped" working. BUT if I open the stream in a separate tab, it takes about 60 secs and voila - the stream appears. OctoRemote on android shows the stream instantly. Strange!
/home/pi/.octoprint/logs has no webcamd.log so no idea where I might find more info about the issue.
If you want to find the webcamd.log, this is in /var/log/webcamd.log
, as it is not part of OctoPrint.
No webcamd.log available there
