Logitech C270
Webcam was working fine in OctoPi Console - I could go to the console tab and it showed straight away perfectly fine.
All default settings - only changed resolution to 1280x720 in the OctoPi file in NotePad++
However, upon logging off and logging back in again the Console tab would show 'Webcam Stream Loading' and never get there - just black screen with that text.
Upon rebooting the server, it would work again, until I logged off again!
Now, even a reboot does not fix it. Doesn't show up at all.
I can enter webcam settings and can see a snapshot fine - so it's definitely connected - just no stream.
However, I can go to http://octopi.local/webcam/?action=stream in a browser and I get a stream perfectly fine every time - proving the camera itself is working fine. It's just the console that doesn't want to show it!
Reboot unit a few times. Checked OctoPi file etc for camera settings - other then resolution, everything is default.
octoprint-logs.zip (240.5 KB)
Octo version: Octoprint 1.8.6
Octopi version 0.18.0
Rbpi v4B, model 8 GB
Completely default setup - only plugin installed is the Prusa Levelling Guide.
