I'm lost
Webcam stream is not loaded. Camera Xiaomi 1080-360 is connected on USB (and normally work correctly as a surveillance camera at home)
lots of things at my level. I tried to change the settings each time on the microSD in octoprint.txt :
this : camera_usb_options="-r 1920x1080 -f 30"
and this : camera_usb_options="-r 1920x1080 -f 15"
and this : camera_usb_options="-r 1920x1080 -f 30 -y"
Yes
Complete Logs
octoprint.filemanager.storage._list_folder(<octoprint.filemanager.storage.LocalFileStorage object at 0xb28e4510>,'/home/pi/.octoprint/uploads',base='',force_refresh=False) took 0.18ms
2021-04-15 00:19:30,827 - octoprint.server.api.files.timings - DEBUG - octoprint.server.api.files._getFileList('local',filter=False,recursive=True,allow_from_cache=True) took 1.45ms
2021-04-15 00:19:30,827 - octoprint.server.api.files.timings - DEBUG - octoprint.server.api.files._getFileList('sdcard',) took 0.01ms
2021-04-15 00:20:20,000 - octoprint.server.util.flask - INFO - Passively logging in user jeanjak from ::ffff:192.168.1.20
2021-04-15 00:20:20,001 - octoprint.access.users - INFO - Logged in user: jeanjak
2021-04-15 00:20:20,009 - octoprint.plugin - DEBUG - Calling on_event on action_command_notification
2021-04-15 00:20:20,010 - octoprint.plugin - DEBUG - Calling on_event on action_command_prompt
2021-04-15 00:20:20,010 - octoprint.plugin - DEBUG - Calling on_event on announcements
2021-04-15 00:20:20,010 - octoprint.plugin - DEBUG - Calling on_event on file_check
2021-04-15 00:20:20,010 - octoprint.plugin - DEBUG - Calling on_event on firmware_check
2021-04-15 00:20:20,010 - octoprint.plugin - DEBUG - Calling on_event on pluginmanager
2021-04-15 00:20:20,011 - octoprint.plugin - DEBUG - Calling on_event on softwareupdate
2021-04-15 00:20:20,011 - octoprint.plugin - DEBUG - Calling on_event on tracking
2021-04-15 00:20:20,011 - octoprint.plugin - DEBUG - Calling on_event on octoeverywhere
2021-04-15 00:20:20,138 - octoprint.server.util.flask - DEBUG - No cache entry or refreshing cache for / (key: ui:_default:https://192.168.1.28/:en), calling wrapped function
2021-04-15 00:20:25,228 - octoprint.server.util.flask - DEBUG - Needed 5.09s to render / (key: ui:_default:https://192.168.1.28/:en)
2021-04-15 00:20:25,260 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.20
2021-04-15 00:20:25,262 - octoprint.plugin - DEBUG - Calling on_event on action_command_notification
2021-04-15 00:20:25,262 - octoprint.plugin - DEBUG - Calling on_event on action_command_prompt
2021-04-15 00:20:25,262 - octoprint.plugin - DEBUG - Calling on_event on announcements
2021-04-15 00:20:25,262 - octoprint.plugin - DEBUG - Calling on_event on file_check
2021-04-15 00:20:25,262 - octoprint.plugin - DEBUG - Calling on_event on firmware_check
2021-04-15 00:20:25,263 - octoprint.plugin - DEBUG - Calling on_event on pluginmanager
2021-04-15 00:20:25,263 - octoprint.plugin - DEBUG - Calling on_event on softwareupdate
2021-04-15 00:20:25,263 - octoprint.plugin - DEBUG - Calling on_event on tracking
2021-04-15 00:20:25,263 - octoprint.plugin - DEBUG - Calling on_event on octoeverywhere
2021-04-15 00:20:25,470 - octoprint.plugins.octoeverywhere - INFO - SetFrontendLocalPort API called. Port:443
2021-04-15 00:20:25,550 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.20
2021-04-15 00:20:25,573 - octoprint.plugin - DEBUG - Calling on_event on action_command_notification
2021-04-15 00:20:25,574 - octoprint.plugin - DEBUG - Calling on_event on action_command_prompt
2021-04-15 00:20:25,574 - octoprint.plugin - DEBUG - Calling on_event on announcements
2021-04-15 00:20:25,574 - octoprint.plugin - DEBUG - Calling on_event on file_check
2021-04-15 00:20:25,574 - octoprint.plugin - DEBUG - Calling on_event on firmware_check
2021-04-15 00:20:25,574 - octoprint.plugin - DEBUG - Calling on_event on pluginmanager
2021-04-15 00:20:25,574 - octoprint.plugin - DEBUG - Calling on_event on softwareupdate
2021-04-15 00:20:25,575 - octoprint.plugin - DEBUG - Calling on_event on tracking
2021-04-15 00:20:25,575 - octoprint.plugin - DEBUG - Calling on_event on octoeverywhere
2021-04-15 00:20:25,588 - tornado.access - WARNING - 404 GET /favicon.ico (::ffff:192.168.1.20) 6.93ms
2021-04-15 00:20:25,596 - octoprint.server.util.flask - INFO - Passively logging in user jeanjak from ::ffff:192.168.1.20
2021-04-15 00:20:25,597 - octoprint.access.users - INFO - Logged in user: jeanjak
2021-04-15 00:20:25,602 - octoprint.plugin - DEBUG - Calling on_event on action_command_notification
2021-04-15 00:20:25,605 - octoprint.plugin - DEBUG - Calling on_event on action_command_prompt
2021-04-15 00:20:25,605 - octoprint.plugin - DEBUG - Calling on_event on announcements
2021-04-15 00:20:25,605 - octoprint.plugin - DEBUG - Calling on_event on file_check
2021-04-15 00:20:25,606 - octoprint.plugin - DEBUG - Calling on_event on firmware_check
2021-04-15 00:20:25,606 - octoprint.plugin - DEBUG - Calling on_event on pluginmanager
2021-04-15 00:20:25,606 - octoprint.plugin - DEBUG - Calling on_event on softwareupdate
2021-04-15 00:20:25,607 - octoprint.plugin - DEBUG - Calling on_event on tracking
2021-04-15 00:20:25,607 - octoprint.plugin - DEBUG - Calling on_event on octoeverywhere
2021-04-15 00:20:26,791 - octoprint.server.api.files.timings - DEBUG - octoprint.server.api.files._getFileList('local',filter=False,recursive=True,allow_from_cache=True) took 0.17ms
2021-04-15 00:20:26,792 - octoprint.server.api.files.timings - DEBUG - octoprint.server.api.files._getFileList('sdcard',) took 0.03ms
2021-04-15 00:20:26,862 - octoprint.server.util.sockjs - INFO - User jeanjak logged in on the socket from client ::ffff:192.168.1.20
2021-04-15 00:20:26,865 - octoprint.plugin - DEBUG - Calling on_event on action_command_notification
2021-04-15 00:20:26,865 - octoprint.plugin - DEBUG - Calling on_event on action_command_prompt
2021-04-15 00:20:26,865 - octoprint.plugin - DEBUG - Calling on_event on announcements
2021-04-15 00:20:26,865 - octoprint.plugin - DEBUG - Calling on_event on file_check
2021-04-15 00:20:26,866 - octoprint.plugin - DEBUG - Calling on_event on firmware_check
2021-04-15 00:20:26,866 - octoprint.plugin - DEBUG - Calling on_event on pluginmanager
2021-04-15 00:20:26,866 - octoprint.plugin - DEBUG - Calling on_event on softwareupdate
2021-04-15 00:20:26,866 - octoprint.plugin - DEBUG - Calling on_event on tracking
2021-04-15 00:20:26,866 - octoprint.plugin - DEBUG - Calling on_event on octoeverywhere
OctoPrint version : 1.5.3
OctoPi version : 0.18.0
Mac Os 11.2.1
I tried since 2 days to make it work and I'm going crazy now...
I tried this in SSH because i read it the guide session but i must admit I'm very begining :
pi@octopi : ~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
pi@octopi : ~ $ /var/log/webcamd.log
-bash: /var/log/webcamd.log: Permission denied
Thank you in advance !
