Webcam not recognized
Bus 001 Device 006: ID 045e:00f4 Microsoft Corp. LifeCam VX-6000 (SN9C20x + OV9650)
Webcam not recognized.
I try to change resolution, remove frame rate, -y option, powered hub.. but nothing.
Starting up webcamDaemon...
cfg_file:      /boot/octopi.txt
camera:        usb
usb options:   -r 640x480
raspi options: -fps 10
http options:  -w ./www-octopi -n --listen 127.0.0.1
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Mar 17 12:04:55 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -d /dev/video0
 i: Frames Per Second.: -1
 i: Format............: JPEG
 i: Could not obtain the requested pixelformat: MJPG , driver gave us: S920
    ... will try to handle this by checking against supported formats.
 i: init_VideoIn failed
Raspberry pi3b.
OctoPrint version : 1.5.3
OctoPi version : 0.18.0
It seems like a lot of peoples have problems using this or similar cams on a pi.
Try even lower resolutions like 320x240 or 160x120
Ff that still doesn't work try to install v4l-utils with
sudo apt update && sudo apt -y install v4l-utils
and run v4l2-ctl --list-formats-ext in ssh.
camera: usb
usb options: -r 160x120
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Mar 17 12:50:49 root: Starting USB webcam
  • It seems that you don't have VL805 (Raspberry Pi 4).
    Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 160x120 -d /dev/video0
    i: Desired Resolution: 160 x 120
Goodbye...
Same result :frowning:
Alright.
Just updated my post - try to run those commands
v4l2-ctl --list-formats-ext should shows us what the camera is capable of
if I try to upgrade:
v4l-utils is already the newest version (1.16.3-3).
pi@octopi:~ $ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'BA81' (8-bit Bayer BGBG/GRGR)
	Size: Discrete 1280x1024
[1]: 'S920' (GSPCA SN9C20X I420)
[2]: 'JPEG' (JFIF JPEG, compressed)
A few years ago mjpg-streamer didn't accept the JPEG pixel format - just MJPG, but that should be fixed in the version you're using.
tbh I'm not sure why it doesn't use it.
I suggest you try to build the latest version
then try to run it with
./mjpg_streamer -i "./input_uvc.so" -o "./output_http.so"
if it works you should be able to get a stream on
http://<your Raspi's IP>:8080/?action=stream
I build the last version, but not working :frowning:
pi@octopi : ~/mjpg-streamer/mjpg-streamer-experimental $ ./mjpg_streamer -i "./input_uvc.so" -o "./output_http.so"
Sry that's all I can do.
You got two options - buy another cam or write a bug report on github.
Maybe they're able to add a fix for your problem.
Thanks so much for your time. I'll do both.
Which webcam do you recommend? that it has a good resolution and that it doesn't cost much.
Thanks again
I do not have high standards when it comes to printer cams.
I would just go with a 1.3 pi cam ( 5MP 1080p) or a clone :slight_smile:
They're cheap (less than 10€ on ebay) and get the job done.
Has this changed? apt says there is no such thing as v41-utils (Unable to locate package v41-utils)?
it's a lower case L - not an 1 :slight_smile:
v4l is short for video for linux
