Camera model Pi Cam. with a Pi4 .. (the log states I dont have a Pi4)
What is the problem? Black screen / not connecting . Was working fine, till there was
an octoprint update last week.
What did you already try to solve it? Reboot . Reconnect Cam
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 1280x720 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
raspi
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Jan 25 12:47:10 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 1280x720 -f 10 -d /dev/video0
i: Desired Resolution: 1280 x 720
i: Frames Per Second.: 10
i: Format............: JPEG
o: HTTP Listen Address..: 127.0.0.1
Goodbye...
i: select() timeout
i: cleaning up resources allocated by input thread
Latest version.
