Raspberry Pi Camera V2
No video feed
Tried this Webcam Setup
Additional information about your setup (OctoPrint 1.5.1, OctoPi 0.17.0)
No video feed
The tutorial you have followed is unlikely to work. All you need to do is follow one of the tutorials linked from https://octoprint.org/download/ which tutorial will depend if you've used the Octopi image or installed Ootoprint on Raspberry Pi OS.
I know have gone there and saw this
You also do not need to manually enable the RaspiCam if you have one, that is already taken care of on the image as well. But in the control tab of OctoPrint the camera does not show any video?
Quick raspicam checklist
This link MJPG Stream works fine but I don't know why the control tab in OctoPrint doesn't show any video?
Did you try another browser?
Are you using the default settings in the octopi.txt or did you change them to a higher resolution/quality?
I have tried microsoft edge. I have not touched the octopi.txt at all
