on a raspberry pi zero 2 w
Camera : raspberry pi camera (B) Rev 2.0
**What is the problem?: The camera is connected and the LED on It is on but on the web page, it's printing ("webcam stream loading..") and it does not change. **
**What did you already try to solve?:
- the test stream URL doesn't show a video.
- add a -y to the octopi.txt file (camera_usb_options="-r 640x480 -f 10 -y") with no change.
- double-check the connections on the camera
- made sure that the camera is enabled in the raspi-config.**
Logs: add as a picture
Additional information about your setup (OctoPrint version, OctoPi version, ...)cam
Sorry the post is upgraded
nice but you forgot to mention which octopi image you're using
use -y just if your usb webcam doesn't support MJPG, pictures will be captured in YUVY
--> not needed for a picam
by octopi image you mean version? if so octopi version:0.18.0 and octoprint version: 1.7.3
These is the logs from " journalctl -u webcamd.logs"
and in pi@octopi:~$ vcgencmd get_camera:
supported=1 detected=1
thanks so much fo the help
I see more and more threads coming up with the Camera problem.
Something got changed bigtime... wish I knew what..
'Something got changed bigtime'? OctoPi 0.18 has been the same for over a year now. The camera streaming software doesn't change on it's own...
