Webcam On-Off Option
I understand that. Shutting down the MJPG Streamer is certainly not as severe as rebooting the whole RasPi. The Script could certainly check to see if others are logged in and using the webcam and give an appropriate warning.
I agree that this could/should be a custom config with OctoPi.
Does OctoPrint installed on a Mac or Windows machine have the "Reboot System" or "Shut Down" menu items or is that specific to the RasPi?
Is this something that could be done thru the "System Command Editor". That plug-in doesn't work on a Mac for some reason. I tried 3 different browsers.
The reboot/shutdown menu items are available (on macOS at least), they're just not preconfigured like on OctoPi. You can set the shell commands for these options manually in the OctoPrint settings under the 'Server' heading.
System Command Editor works for me, Safari 11.1 on 10.12.6 Sierra, albeit with the double scroll bar rendering glitch. Are you using any content blockers or similar?
Like @lbell mentions, if you use system command editor you can set the commands to
sudo service webcamd stop for stopping the webcam service
and
sudo service webcamd start for starting the service.
Of course webcamd in the commands above have to match the name of the service you add. That name is specific to OctoPi.
Hi, It worked for me adding in the system command editor:
turn on: sudo /etc/init.d/webcamd start
turn off: sudo /etc/init.d/webcamd stop
Keep in mind that activating the webcam takes about 30 or 40 seconds to activate the service
Nube here. I get am error when executing these command after I entered them, because sudo is requesting the root password.
And would this be on an OctoPi-imaged OctoPrint on a Raspberry Pi? If so, then Guy would have taken care of all this since his image rocks.
See lines 134-136 for what he did to allow pi to quietly do things like shutdown, for example.
I started over, re-imaged, updated, and now the control commands are working. Very nice. Thank you!.
Is there any way to trigger system commands on events, like the GCODE Scripts section does? I'd like to make the camera automatically turn on when a print is queued and turn off when it's done.
  1. Take the scripts which jneilliii has provided above
  2. Turn them into Gcode System Commands as, say, 900 and 901
  3. Add the OCTO900 and OCTO901 as appropriate into your OctoPrint Gcode scripts as if they were GCODE
Is it possible to connect xioami Dafang wiwfiweb camera to raspberry pi with octoprint
I realize this is rather old, but anyways I am using the actual Octopi image 1.5.2.
There is no webcamd script in that installation and it seems octopi is doing the webcam stuff by itself.
How would I shutdown the wbcam there and possibly restart it?
Wouldn't it be much better, if Octopy would handle that by itself? Maybe just starting the webcam if someone connects to the webinterface?
What am I missing?
Cheers
I think you might be confused between what OctoPi is and what OctoPrint is - your post contradicts itself.
You can control webcamd using sudo service webcamd {start|stop|restart}. Starting the camera when someone connects could be done with a plugin that ran this command for you, but it is not built in because webcam streaming is not provided by OctoPrint, it is only getting an MJPG stream from the URL and so cannot control it.
Thanks Charlie,
I realize the difference between Pi and Print. Nevertheless atleast the Octoprint settings menue has options to controll some things about the webcam. I know it's basically what to do with the stream but what would be the harm in setting those start and stop service commands in that section and running them when necessary?
Anyways thanks to you help, I used the system command plugin to make the corresponding system menue entries and it works - not automatically. At least I now have control over the webcam using Octoprint's system menue.
Thanks again for you help
Cheers
try this:
turn on: sudo service webcamd start
turn off: sudo service webcamd stop
I did this by using GCODE System Commands plugin with two command definitions:
OCTO910 sudo service webcamd start
OCTO911 sudo service webcamd stop
Then inserted these codes to GCODE Scripts:
"After connection to printer is established"
OCTO910
and
"Before connection to printer is closed"
OCTO911
Now the camera goes on when printer powers on and connection to Octoprint is established.
When printer power is lost and Octoprint connection is cut the camera goes off.
I'm using Tasmota plugin to control the printer power but Octopi is always powered on.
I am just starting in 3D printing and have probably spent more money than I needed to for how often I will use it :slight_smile:
Anyway, I found this looking for the ability to turn webcam off on Octoprint and wanted to say thank you for all the information. It only takes a few seconds for the service to stop / start now rather than 30 seconds plus, but apart from that all information is still relevant now.
Now to work out how to turn the printer power off at the end of a print :slight_smile:
hyptechdev2015
jlester42
Jan '21
essaye ça:
activer : sudo service webcamd start
désactiver : sudo service webcamd stop
Bonjour,
je suis intéressé par la commande on/off
mais ou doit on écrire cela dans Putty, comment accéder à l'éditeur de commande, je ne voudrais pas mettre le bazar dans mon Raspi, je sais ouvrir et rentrer ID et MP mais qu'écrire pour arriver dans éditeur de commande
si quelqu'un ou quelqu'une peut m'aider, d'avance merci
And docker user could use:
OCTO910 s6-svc -u /var/run/s6/services/mjpg-streamer
OCTO911 s6-svc -d /var/run/s6/services/mjpg-streamer
Just to keep this up to date - with the new camera stack (now testing in 1.9.2) these commands would be:
OCTO910: sudo /usr/sbin/service camera-streamer start
OCTO911: sudo /usr/sbin/service camera-streamer stop
Enjoy!
Hi guys,
I need to bring this topic up again, because I am not able to get the camera to start automatically by using OCTO910 (after connected to the printer) and stopped by using OCTO911 (before printer is being disconnected).
System Command Editor scripts are working fine though and scripts look as follows (as already stated above):
My GCODE scripts are simply (afterPrinterConnected)
;Start Webcam
OCTO910
and (beforePrinterDisconnected)
;Stop Webcam
OCTO911
Just to be on the safe side I also entered OCTO911 to more scripts:
afterPrintDone, afterPrintPaused, afterPrintCancelled
Nothing is working.
What am I missing or doing wrong here?
