Continuing the discussion from Raspberry Pi Camera V2 Settings?:
How do you check and see what resolution the raspberry pi camera is outputting? Is there a command line that will show all the camera settings?
Not directly as far as I know.
but you can
ps -aux | grep mjpg_streamer
you will then see the current mjpg streamer process and its command line option, where resolution should be set.
next you can
cat /boot/octopi.txt
(while under octopi SD card system, i don't know about standalone octoprint instalation in raspbian)
and see something about these settings.
