What is the problem? Wyze Cam V2 Drops feed midprint
What did you already try to solve it? I looked through logs and tried to understand. Maybe cause i dont use webcam 1 anymore and left all info the same. So Wyze is still seen as webcam 2?
Additional information about your setup (OctoPrint version, OctoPi version, ...) Octoprint = 1.7.3, OctoPi = 0.18.0 Python = 3.7.3
This cam has been doing this since i set it up as webcam 2. Shorter prints its ok but extended prints it will eventually drop the feed, Hope i set up all needed info. If theres anything else needed let me know. I thank you and bid yall a good day!
How is the cam connected? Via wifi?
If yes - are you still able to connect to the stream url when it dropped in OctoPrint? (just open the stream url in a browser)
Its connected usb. It does not pull up on the browser once it has been lost in octoprint. I have to unplug and plug back in both cables to get the feed back.
