Webcam snapshot url works, but stream url doesn't
Arducam 5mp OV5647 camera
I try to set the Pi up, but when I get to the camera setup, the stream URL doesn't work. The snapshot URL works fine, but the second I try to test the stream, nothing shows on the screen.
I had a different problem before, but I troubleshooted using recommendations on this website to fix the original problem. I have ran in safe mode, typed in every command that Bing Ai would give me, and tried reflashing octoprint. The camera itself works, because the snapshot works. I tried typing in the stream url and opening it in a browser. “Http://myIP/ I also tried “sudo system to restart webcamd”.
Yes.
No.
octoprint-systeminfo-20240117191655.zip (8.3 KB)
I have the newest stable version of OctoPi on the flashing software, my pi is a 3B, I haven’t connected it to the printer. It is connected to an Ethernet cable, and I have high-speed Wi-Fi, so connectivity is not an issue. It is connected to an Arducam in a case, and I don't think the camera itself is the problem, because the snapshot URL works.
which one exactly, there are two (stable and new camera stack). Since you didn't share a system info bundle we can't tell.
I have the stable. Thank you for the quick response! I couldn't share the info bundle because I haven't finished setting octoprint up. The test for camera streamer didn't work, so I didn't want to keep going for a third time before getting it to work.
I have the exact same problem as you. I would really really really really appreciate it if you could tell me how you got the camera working as it doesn't work on octoprint or klipper mainsail.
Hello @Miah_Papaya !
For it does not work on either: It seems the webcam is faulty or the driver.
