Generic 1080p Webcam
lsusb says "Bus 001 Device 005: ID 05a3:9331 ARC International Camera"
The camera disconnects irregularly. I have no idea why it could be.
Recently, I have been monitoring the connection of the webcam. Unfortunately, the data does not yet give me any information about the cause.
Since I started monitoring, the webcam has been running at the following times:
- 2022-03-27 17:12:55 - 2022-03-30 18:40:39
- 2022-03-30 19:00:30 - 2022-04-01 03:15:39
- 2022-04-01 09:27:30 - 2022-04-01 09:54:39
In these times, I mainly printed or the Pi didn't do anything.
After a restart, the webcam was accessible again.
With the last entry, I stopped a print before the connection was lost.
Since I sometimes also had problems uploading data, I looked to see if the CPU or RAM were causing problems during these times, but these values are all in the normal range at the same time.
webcamd.log
i: select() timeout
i: cleaning up resources allocated by input thread
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: usb
usb options: -r 1920x1080 -f 20
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Apr 1 10:30:52 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 1920x1080 -f 20 -d /dev/video0
i: Desired Resolution: 1920 x 1080
i: Frames Per Second.: 20
i: Format............: JPEG
i: FPS coerced ......: from 20 to 30
o: HTTP Listen Address..: 127.0.0.1
Goodbye...
syslog
Before each crash, the same two messages come:
Apr 1 03:15:04 octopi MJPG-streamer [480]: select() timeout
Apr 1 03:15:04 octopi MJPG-streamer [480]: cleaning up resources allocated by input thread
I use the following versions on a Pi 3B:
- OctoPrint 1.7.3
- Python 3.7.3
- OctoPi 0.18.0
