Hello!
I successfully managed to get my webcam (Papalook 720p webcam from amazon) to work just fine with Octoprint 1.3.8 on a RPi 3B. It works in multiple resolutions and framerates. CPU usage of haproxy is between 3-6%, mjpg_streamer 2-3%. Steady stream, very little delay after I dropped wifi on the RPi and plugged an ethernet cable.
After ~10-15 minutes the stream stops. I'm having trouble pinning down the reason.
Looking through google I suspected a powersupply issue. I'm using the original Raspberry PSU and measured 4.5V, so I added a powered USB-Hub and now measure 4.83V steady on the hub, I also placed the multimeter in the frame and on the last frame it was still 4.83. I guess this is not the issue. I have also tried to look through all sorts of logs but being rather new to Linux makes it a bit difficult to pin down the problem, so I figured it might be best to ask here.
Octoprint 1.3.8
OctoPi 0.14.0
Anet A8 on Ramps 1.4 and Marlin 1.1.8 Bugfix
PAPALOOK PA150 Webcam
lsusb output:
pi@octopi:~ $ lsusb
Bus 001 Device 006: ID 0c45:6340 Microdia
Bus 001 Device 005: ID 05e3:0605 Genesys Logic, Inc. USB 2.0 Hub
Bus 001 Device 004: ID 2341:0042 Arduino SA Mega 2560 R3 (CDC ACM)
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
dmesg output camera related:
[ 3.425573] media: Linux media interface: v0.10
[ 3.477084] usbcore: registered new interface driver brcmfmac
[ 3.482706] Linux video capture interface: v2.00
[ 3.507173] usb 1-1.5.1: 3:1: cannot get freq at ep 0x84
[ 3.523981] usbcore: registered new interface driver snd-usb-audio
[ 3.616050] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.660492] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (0c45:6340)
[ 3.674738] uvcvideo 1-1.5.1:1.0: Entity type for entity Extension 4 was not initialized!
[ 3.674760] uvcvideo 1-1.5.1:1.0: Entity type for entity Processing 3 was not initialized!
[ 3.674772] uvcvideo 1-1.5.1:1.0: Entity type for entity Camera 1 was not initialized!
[ 3.675364] input: USB 2.0 Camera as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5.1/1-1.5.1:1.0/input/input0
[ 3.675517] usbcore: registered new interface driver uvcvideo
[ 3.675522] USB Video Class driver (1.1.1)
/var/log/haproxy.log:
Apr 16 09:41:09 octopi haproxy-systemd-wrapper[799]: haproxy-systemd-wrapper: SIGINT -> 801
Apr 16 09:41:09 octopi haproxy-systemd-wrapper[799]: haproxy-systemd-wrapper: exit, haproxy RC=0
Apr 16 09:41:24 octopi haproxy-systemd-wrapper[810]: haproxy-systemd-wrapper: executing /usr/sbin/haproxy -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -Ds
Apr 16 09:41:24 octopi haproxy-systemd-wrapper[810]: [WARNING] 105/094124 (812) : Setting tune.ssl.default-dh-param to 1024 by default, if your workload permits it you should set it to$
Apr 16 09:44:44 octopi haproxy-systemd-wrapper[810]: haproxy-systemd-wrapper: SIGINT -> 813
Apr 16 09:44:44 octopi haproxy-systemd-wrapper[810]: haproxy-systemd-wrapper: exit, haproxy RC=0
Apr 16 09:44:59 octopi haproxy-systemd-wrapper[804]: haproxy-systemd-wrapper: executing /usr/sbin/haproxy -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -Ds
Apr 16 09:44:59 octopi haproxy-systemd-wrapper[804]: [WARNING] 105/094459 (807) : Setting tune.ssl.default-dh-param to 1024 by default, if your workload permits it you should set it to$
output of: v4l2-ctl --list-devices
USB 2.0 Camera (usb-3f980000.usb-1.5.1):
/dev/video0
I did not find a logfile for mjpg-streamer ...
Also here the octoprint log:
octoprint.log (379.9 KB)
I would be super thankfull if somebody could guide me through where else I could look to pin down why it stops.
Thank you very much!
