Chinese generic 1080p
Since I changed to Raspberry 4 a lot of problems with the WebCam. It worked fine for a couple of prints and stopped working. I don' know what more to do.
I uploaded everything and I changed octopi.txt with:
camera_usb_options="-r 640x480 -f 3 -y"
Webcam.log
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device$/root/bin/webcamd: line 184: printf: 0x: invalid hex number
<13>Oct 3 16:32:32 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /de$MJPG Streamer Version: git rev: 5554f42c352ecfa7edaec6fc51e507afce605a34
i: Using V4L2 device.: /dev/video10
i: Frames Per Second.: 10
i: Format............: JPEG
Error opening device /dev/video10: video capture not supported.
i: init_VideoIn failed
Goodbye...
Starting up webcamDaemon...
Octoprint.log
Attached but I think the more important part is:
2021-10-03 10:41:34,558 - backoff - INFO - Backing off capture_jpeg(...) for 0.8s (requests.exceptions.ReadTimeout: HTTPConnectionPool(host='127.0.0.1', port=8080): Read timed out. (read timeout=5))
2021-10-03 10:41:40,409 - backoff - INFO - Backing off capture_jpeg(...) for 0.5s (requests.exceptions.ReadTimeout: HTTPConnectionPool(host='127.0.0.1', port=8080): Read timed out. (read timeout=5))
https://drive.google.com/file/d/1uz4NlKWau_AgGR2iBuKSj2Evd6Lg3t_w/view?usp=sharing
