RPi Camera Module 3
The control page shows "Webcam stream loading" in the viewer forever.
Power cycle of whole system. Also checked to see if the camera was recognized at the command line:
supported=1 detected=1, libcamera interfaces=0
Yes
Nope
attached
octoprint-systeminfo-20251205172217.zip (20.9 KB)
Raspberry Pi 4 B, browsing from Mac OS & Safari. Was working fine before I reflashed my card to update Python. I restored the previous setup from a backup (using OctoPrint's backup/restore).
Someone mentioned that the legacy camera lib might no longer work, so I tried rpicam-hello at the command line and indeed it said no cameras detected. So I went into config.txt and turned camera autodetection on, then rebooted.
Now rpicam-hello reports finding the camera, but the OctoPrint stream still doesn't work. Here's the output; I figured the last error was because OctoPrint is using the camera, but I don't know...
[0:06:53.880579502] [994] INFO RPI vc4.cpp:447 Registered camera /base/soc/i2c0mux/i2c@1/imx708@1a to Unicam device /dev/media4 and ISP device /dev/media1
[0:06:53.880644511] [994] INFO RPI pipeline_base.cpp:1126 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
Preview window unavailable
Mode selection for 2304:1296:12:P
SRGGB10_CSI2P,1536x864/0 - Score: 3400
SRGGB10_CSI2P,2304x1296/0 - Score: 1000
SRGGB10_CSI2P,4608x2592/0 - Score: 1900
[0:06:53.882810108] [991] INFO Camera camera.cpp:1197 configuring streams: (0) 2304x1296-YUV420 (1) 2304x1296-SBGGR10_CSI2P
[0:06:53.883060070] [994] ERROR V4L2 v4l2_videodevice.cpp:1072 /dev/video0[14:cap]: Unable to set format: Device or resource busy
ERROR: *** failed to configure streams ***
